89 GTS jerking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-23-2009, 07:52 AM   #1 (permalink)
View misterspockyall's Photo Gallery
89 GTS jerking
Hello all, I've owned an 89 Corolla GTS for nearly 3 years. In certain situations I experienced what I deemed to be "normal" jerking of the car when decelerating in 1st or 2nd gear.
In recent months, however, this jerking has significantly increased to the point that if I don't ride the clutch heavily for take offs and shifts into second, it jerks violently front to back until I mash the throttle and get around 3500rpm in 1st or 2nd. This problem is more noticeable with slower take offs (driving through parking lots, etc.) and almost non-existent when "launching" the car with greater acceleration. Did I mention that I have a pretty significant exhaust leak as well (Back pressure issues?)
I've changed the spark plugs and WD40'd the throttle cable at the motor and the pedal. Other threads mentioned something about the TPS and the device that slows the deceleration of the throttle(name escapes me).
The throttle deceleration device seems to work ok, I do not know what a TPS is to locate it under the hood.
Sorry if this question has been addressed in the past, but does anyone have any advice. I'd love to keep this car as we have a couple of kiddos at home and the budget is tight. Not to mention that I love this car!
Thanks
misterspockyall is offline   Reply With Quote
Old 04-23-2009, 11:24 AM   #2 (permalink)
Blof-fan's Avatar
Gameroom cash: $294750
View Blof-fan's Photo Gallery
TPS=Throttle Position Sensor
It's on the back of the throttle housing. The round black thing with a connector attached to it
A picture of my website that might help:
Be carefull though...it's quite delicate.
How is you're clutch?? I think you should look for the problem there...
Driving : '92 Toyota T19 Carina E GTi
Repairing : '92 Toyota AE92 Corolla Hatchback GTSi
Restoring : '88 Toyota AE92 Corolla Coupé GT-S
My personal website: http://www.corollaae92gts.nl
Blof-fan is online now   Reply With Quote
Old 04-23-2009, 11:53 AM   #3 (permalink)
Thanks for the pic, I'll take a look and definitely be careful. My mechanic told me last year that it felt like it was towards its end, although it was functional. That was a year ago however, I suspected it might be the clutch, but I'd never had one go out, so I don't know what it feels like. The shaking begins once I've let my foot off the clutch entirely.
Old 04-23-2009, 12:27 PM   #4 (permalink)
Rawr!
aHarmony's Avatar
View aHarmony's Photo Gallery
I have the same issue with my carbureted 4-AF sedan, so it's NOT the TPS causing it.
Others have told me it has to do with worn out engine mounts. If you tap the throttle rhythmically, does the car shake out of its own momentum? If so, it's probably the engine mounts. Kinda scary but true.
4-AF clutches are extremely long lasting because of the lack of power output. There was a thread where members were all laughing about their serious clutch abuse and the thing still holds out after 200k of mileage and years of clutch dumping in 2nd and stuff, so I don't think it's the clutch.
Clutches wearing out (from what I know) primarily 'slip'. Say when you release the clutch when it should normally work, instead it will not grab and engage driving...you will hear the revs go up as if the clutch is not engaged even if the pedal is fully let off kinda thing. I'm sure there are other things that can go wrong related to the clutch (ie: flywheel gears shearing from abuse), but the clutch itself is simply a grip pad and as far as I know the only thing it can do wrong is stick in place (not very likely - would more likely be caused by the clutch controls having issues) or more commonly slip when trying to grab.
That being said, I have not properly diagnosed or solved our problem. I am quite certain though that it is the mounts...others told me it could be the carb, but if you're having it on EFI than it's probably not true.
Unless you do the mount replacement yourself (if that is indeed the case) it's not worth it for a car of this value to get it done by the shop I don't think
Post back with your findings. Maybe the clutch is doing it, but I'm doubtful.
Cars - '88 Corolla DLX Sedan (4-AF)
aHarmony is offline   Reply With Quote
Old 04-23-2009, 07:44 PM   #5 (permalink)
View kcwa's Photo Gallery
Put your car in 4th or 5th gear...which ever is highest. See if you can let the clutch out and take off from that gear. If you can, then the clutch is worn out. If the clutch is good the car should stall out in that high of gear.
1990 Corolla SR5 Coupe 4AFE 5-speed
"Gentlemen, you can't fight in here! This is the War Room!"
~ Dr. Strangelove, 1964
kcwa is offline   Reply With Quote
Old 04-23-2009, 07:44 PM   #6 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Consider vacuum leak and gummed up throttle plate also.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 04-23-2009, 07:53 PM   #7 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
At least some carbed 4AFs have TPS. I know mine does, can't speak for 'em all though. Does it shake on the highway at partial throttle sometimes?
As mentioned though, it's probably the motor mounts. Do you get a Check Engine Light?
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 04-24-2009, 02:34 PM   #8 (permalink)
AE92 3SGTE
View erixon's Photo Gallery
I couldn't give you much info, I haven't had much Jerking experience in my GT-S.
erixon is offline   Reply With Quote
Old 04-24-2009, 04:28 PM   #9 (permalink)
Blof-fan's Avatar
I had my 3S-GE Carina shutter as the clutch just slipped, grabbed on...slipped, grabbed on again etc. when I was going up a steep hill in 5th gear on the freeway. It felt like I was on a very bad road.
Replaced the clutch and everything was well again. :-D
In my Corolla (with nearly 400.000km on the original clutch!) the clutch was getting worn and I had some jerking back and forth aswell sometimes. Not to bad yet, but I was getting worse.
For that clutch test kcwa mentioned before, the car should stall in 3rd gear aswell. If you can drive away in 3rd...then it might be worth while to look at the clutch.
As for the enginemounts...I never really heard of that problem...even with older cars. I'm not saying that couldn't be it. But it wouldn't be the first thing I'd think of
Old 04-24-2009, 07:40 PM   #10 (permalink)
iTrader Score: 16 reviews
View TRDKAMURI99's Photo Gallery
I had a similar problem. It turned out to be torn intake pipe (rubber hose between throttle and AFM). Take it off and inspect it.
TRDKAMURI99 is offline   Reply With Quote
Old 04-27-2009, 07:47 AM   #11 (permalink)
Thank you for all of your quick responses. No check engine light, I am going to look into swapping out the motor mounts as that seems to be the most likely of the problems (I think). I found a few aftermarket upgrade mounts for an 89 GTS that were pretty expensive. Any ideas on where to find these parts? I'm assuming "normal" parts shops won't have them in stock given my last few parts hunts for this car.
Thanks again!
Old 04-27-2009, 08:40 AM   #12 (permalink)
Donald's Avatar
Thanks again!
Advance Auto Parts, Autozone, or NAPA will either have in stock, or can order them for you.
Old 06-25-2009, 06:27 PM   #13 (permalink)
View Call Me Toyota Guy's Photo Gallery
How's your rear sway bar?
It may be the problem. Let me know if you need more info or where to find one I can search for you on ebay.
Call Me Toyota Guy is offline   Reply With Quote
Old 06-25-2009, 07:05 PM   #14 (permalink)
View Duy-'s Photo Gallery
i dont want to sound stupid but, did you check your air intake hose for rips like TRDKAMURI99 originally suggested?
Duy- is offline   Reply With Quote
Old 06-27-2009, 12:11 AM   #15 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
wtf? stop spamming your sway bar dude.
