problems after I changed cv joint on 91 corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-10-2009, 08:51 AM   #1 (permalink)
corolla
View bgtg's Photo Gallery
my 91 was clunking badly on drivers side so I changed the cv joint. I drove it for a little and now it is locking up in drive and I put into reverse and it moves for a little and locks up and then moves in forward a bit and locks up again????? what did I do wrong? what do I need to do to it to fix it???? any help is greatly appreciated. thanks tg
bgtg is offline   Reply With Quote
Old 05-10-2009, 09:01 AM   #2 (permalink)
View kcwa's Photo Gallery
Why don't you try lifting the front of the car, put the tran in neutral and hand roll each wheel to see if it rotates freely or not...if not, look under to see if it is hitting or binding on something. Is tran auto or manual?
1990 Corolla SR5 Coupe 4AFE 5-speed
"Gentlemen, you can't fight in here! This is the War Room!"
~ Dr. Strangelove, 1964
kcwa is offline   Reply With Quote
Old 05-10-2009, 12:53 PM   #3 (permalink)
View PILOT941's Photo Gallery
Gen6
Be very careful, because you could damage the tranny. I would try taking the part back and reinstalling it. Something wasn't done right. The part may also be defective. CV axles are a bitch at times. I just did mine. Good luck to you.
PILOT941 is offline   Reply With Quote
Old 05-10-2009, 01:31 PM   #4 (permalink)
Another thought...was the new axle one piece or two piece?
Old 05-10-2009, 01:46 PM   #5 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Question
oH shit! I hope the C-Clip --retainer at the end of the axle shaft that is at the tranny end-- did not fall off into the trans!
1989 Toyota Corolla SR5, Carb.
1993 Camry LE
retiredat44 is offline   Reply With Quote
Old 05-10-2009, 03:44 PM   #6 (permalink)
corolla
thats what I was thinking about the c-clip. If it did fall off or get damaged, how can I get it out. can I get into the transaxle easily somehow to check it?
Old 05-10-2009, 05:32 PM   #7 (permalink)
AE92
It comes as one piece, but if you neglect to repair it.....it will be two.
