1991 Corolla dies when MAP unplugged
Hello,I have a 1991 Corolla 1.6 (6 vin code) that has been idling rough. Check engine light has been on for a while. I was able to pull codes 25,26 and 31. I unplugged MAP sensor(code 31) and the car died immediately. The other two codes are for lean and rich conditions. I know the MAP should not cause the car to totally die so I'm not sure what this means. Lack of fuel? Vacuum is 18-19. Checked PCV,cannister purge. They test OK. I'm going to replace fuel filter since it's overdue. Thanks for any help.
