yea but you have to replace way more stuff...
you need intake manifold supercharger Assy. pully, i'm sure some electronics (magnetic clutch)
it's more expensive/hp gain
Why would you have to change more stuff?
Just throw on a roots and get a belt that fits. Plumb the piping to a pressure box surrounding the carb. Tadaa... Youd need a bypass valve for the idle, if the air doesnt suffice whats being sucked past the rotors, nothing too hard, magnetic clutch is easy to handle, you can make a madmax style switch if you want
With efi it would be even more easy, for example my KMS has a relay that switches at a predetermined point, you can put RPM in it and Load factor, then when thats passed, it would close the relay and lock the magnetic clutch.
I sorta regret not going that route myself.
