4AF'in lag - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-21-2009, 09:10 PM   #1 (permalink)
View daemonside's Photo Gallery
4AF'in lag
So I got this problem, well not really a problem, but it's pissing me off. Anyway I drive an '89 5 speed 'rolla with a 4AF. My issue with it is that it takes forever for the damned thing to move. I did a full tune-up, added an oil catch can, and replaced the resonator with a pipe. It should be faster! Even just the tiniest bit, but it's not. It takes me forever to get up to say 30 or 40 and then it will decide to either puts along or haul ass. The only possible problem I can think of is a while back(before the tuneup), I had to turn the idle speed up alot to keep the car running when I had practically no spark (crunchy distributer contacts). I turned i t back down later, but maybe too low. Any ideas? I really don't expect this car to knock my head back into the seat, but It does frazzle me so when an old-broken dodge minivan driven by yogi bear flies past me at a light without any effort. Sorry 'bout the rant. Thanks in advance.
daemonside is offline   Reply With Quote
Old 05-21-2009, 09:26 PM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316600
View SCT's Photo Gallery
AE92
Check your vacuum lines and timing. Sounds like your timing is late.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 05-22-2009, 12:49 PM   #3 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
While checking all the vac lines for leaks be sure to check the vac lines at distributor vac advance unit for leaks. Also check the centrifical advance weights inside the distrib for binding. Take the cap off and turn the distributor rotor clockwise . When you release it should spring back. If not the weights are sticking and need lubed or one of the springs is broken. Will have to consult a manual for the teardown procedure. As mentioned before you aren't gonna get whiplash from the power of this engine but it shouldn't be that pokey either.
90 GP is offline   Reply With Quote
Old 05-22-2009, 08:07 PM   #4 (permalink)
All the vac lines check out...as far as the distributer thingy goes...I have no clue, but I need to check that out tomorrow. Thanks alot guys.
Old 05-22-2009, 09:37 PM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
bad timing maybe... look into that.
