I had a oil leak with my Valve cover, and replaced it this weekend. The engine had oil all over it, so I used a engine cleaner and washed it down with a garden hose. I started the car about 5 mintues later and it ran without any problems.
Well today, I try to start the car and nothing happens. The engine turns and turns and I do smell gas. I replace the spark plugs but still nothing.
What did I do (get wet) that won't allow the car to start.
1. Don't wash a hot engine; let it cool for at least two hours before hitting it with water,
or you could crack something from temperature shock.
2. Don't wash an engine that's not running. It's a good way to never have the engine run again.
How long did you run the car when you were testing it? I would've taken it on a good long
drive to get the engine hot and evaporate any water the dripped where it shouldn't. If you
just ran it briefly, I could see water sticking around and dripping where it shouldn't.
Check the coil wire too. Pull it out of the coil and spray it down with the WD-40 to remove all possible moisture.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
