Hesitation between 2000 and 3200 rpm - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2009, 10:19 PM   #1 (permalink)
View Gsr Mann's Photo Gallery
When driving in 2nd or 3rd at the above mentioned rev range the car is sluggish, especially when driving up hill, when the revs pass 3200 it revs as normal. the car runs great above that rev range.
The engine is a 4AFE 1600, I have changed distributor, plug wires, rotor brush, distributor cap, computer, coolant temp sensor, MAP sensor.
The o2 sensor is relatively new. the TPS and vacuum lines was also checked.
Pls give any ideas as to what might be the problem.
Thanks
Gsr Mann is offline   Reply With Quote
Old 05-25-2009, 01:56 AM   #2 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Thanks
take it to a shop and have them connect the diagnostic machine up and see what's wrong..
IMHO
1989 Toyota Corolla SR5, Carb.
1993 Camry LE
retiredat44 is offline   Reply With Quote
Old 05-25-2009, 03:45 PM   #3 (permalink)
the scanner port was bridged no codes came up.
Old 05-26-2009, 07:59 AM   #4 (permalink)
I didn't mean a scanner. I meant a diagnostic computer.. that shows all the workings.. Spark timing and strength.. etc..
or keep messing with it..
1993 Camry LE
Old 05-26-2009, 10:21 PM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
These are pre scanners car aren't they? Your only diagnostic scanner as far as I remember is bridging T1 and E1.
Old 05-27-2009, 12:29 PM   #6 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Have you checked your timing with a strobe light?
Are there any modifications to your intake or exhaust system?
Automatic or manual?
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
