Can't figure out why someone would get a 1991 motor and drop it into a 1997 chassis.
Likely, the wirings were not the same. So, in order to compensate, you have what you have... Cold start switch, etc. The engine need the sensors, just like a person needs nerves to feel or else you'll cut yourself and bleed to death without knowing. Cold starting pretty much allows an engine to run from a cold temperature, not specifically talking about 32 degree or anything, until the engine warms up to normal temps. Basically controls the air/fuel mixture.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
