Brakes? What brakes -.- - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-29-2009, 11:44 PM   #1 (permalink)
View cEtnA's Photo Gallery
so i was driving on the freeway and when i started pushing my brake after a while i lost resistance and even if i pushed it to the floor my stoping power was ziltch i had to use my ebrake -.- whats wrong with my car?!?!?!?!?
cEtnA is offline   Reply With Quote
Old 05-30-2009, 12:38 AM   #2 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
Do you have any fluid in the reservoir?
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 05-30-2009, 08:13 AM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
line/hose ruptured most likely
Old 05-30-2009, 01:34 PM   #4 (permalink)
Blof-fan's Avatar
Gameroom cash: $294750
View Blof-fan's Photo Gallery
Or air in them...was there any work done on the brakes recently?
Probably a hydraulic problem.
Driving : '92 Toyota T19 Carina E GTi
Repairing : '92 Toyota AE92 Corolla Hatchback GTSi
Restoring : '88 Toyota AE92 Corolla Coupé GT-S
My personal website: http://www.corollaae92gts.nl
Blof-fan is online now   Reply With Quote
Old 05-30-2009, 03:22 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
air would make them feel spongy, but he lost them totally, which means a rupture in the hydraulic circuit.
Old 05-31-2009, 05:16 AM   #6 (permalink)
Blof-fan's Avatar
Well, that should be easy enough to check.
Just look in the wheel wells at the flexible lines. Those are probably the first to go.
Old 05-31-2009, 09:30 AM   #7 (permalink)
View kcwa's Photo Gallery
cEtnA, did you have a chance to check the fluid level? Curious what you found...
1990 Corolla SR5 Coupe 4AFE 5-speed
"Gentlemen, you can't fight in here! This is the War Room!"
~ Dr. Strangelove, 1964
kcwa is offline   Reply With Quote
Old 05-31-2009, 10:11 AM   #8 (permalink)
David*All-Trac's Avatar
View David*All-Trac's Photo Gallery
If you attempt to use the brakes several times when there's no fluid ... you may need to change the master. This piece does not run empty...
2001*Corolla S*
1997*Corolla DX
1985*Landcruiser*BJ70*
1982*Landcruiser BJ42*
David*All-Trac is offline   Reply With Quote
Old 05-31-2009, 06:42 PM   #9 (permalink)
ok so i checked today and all the lines seems to be ok and i have fluid the only thing i noticed was the rotar is a bit dirty (sorry for late replys)
Old 05-31-2009, 09:31 PM   #10 (permalink)
...maybe the wheel cylinders are rusted and dirty and not working as they should. I swapped out my wheel cylinders when I just did my brakes...I am about to swap out the master cylinder and replace the brake lines with braided.
Old 06-02-2009, 03:02 PM   #11 (permalink)
Danno
View 89yotarollagts's Photo Gallery
ima thread jack a bit cause im having issues as well...
Over the winter i had removed K-member/engine & removed only the 2 front brake lines...
The fluid ran dry (yes my mistake) went to put everything back together an thought i would replace my master cyl since id have to bench bleed it again anyways (an i want my brakes in tip top condition so new parts are allways nice) i then buttoned everything up an i have a very spongy pedal, thinkin i had air i gravity bled/pressure bled the system for along time (long story short ive ran about 2 jugs through) & still no brakes !! i can get them to barely lock up but i have to put 100lbs of effort into pushen the pedal down...
so to break it down...
i have new rubber lines in front (possible they were damaged on ground but i dont think so)
new rear caliper
new master cyl
ive taken apart all 4 corners, cleaned & re lubed the slided !
OEM booster & proportioning valve..
No fluid leaks !!! but im guessing its getting air somewhere..
my guess would be the booster is bad or out of adjustment ?
ive given up an car is going into toyota on friday since i dont have time to mess with it before my next event.. but curious what you guys think..
~Dan
"True car enthusiasts are open-minded to everyone's creation"
"Straight Roads are for Fast cars... Curvy Roads are for Fast drivers "
89yotarollagts is offline   Reply With Quote
Old 06-02-2009, 05:28 PM   #12 (permalink)
Resident asshole
Flashmn's Avatar
Brake booster failure wont leak out fluid, not will it cause brakes to disappear. Broken booster will make brakes very hard though, as you have no assist on them.
Gravity bleeding seldom works, air it with a friend.
Old 06-02-2009, 07:34 PM   #13 (permalink)
Danno
i have gravity & pressure bled with "a friend" many times !! we went through 2 big jugs of fluid so im guessing something aint right...
Old 06-02-2009, 09:43 PM   #14 (permalink)
View daemonside's Photo Gallery
I had a similar issue. Replacing the wheel cylinders fixed it.
daemonside is offline   Reply With Quote
Old 06-03-2009, 12:28 PM   #15 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Check for a bad/loose wheel bearing.
If you have a wheel that is wobbling because of a loose bearing, it will push the piston further into the caliped/cylinder than is normal. This will require extra pumping to get the brakes to work.
This happened to my son's civic a few months ago.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
