car clunks when you put it in reverse - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2009, 05:47 PM   #1 (permalink)
View gameguru1360's Photo Gallery
I've noticed lately that my 91 corolla dx auto tranny clunks when I shift it into reverse either from park or drive.
Would most of you say that this is the U-joint or is it the entire auto tranny?? How much does this part usually go for and can I go to a regular mechanic or is it specifically only handled by transmission repair centers??
gameguru1360 is offline   Reply With Quote
Old 06-01-2009, 06:58 PM   #2 (permalink)
View ericdude's Photo Gallery
I don't believe the FWD corolla has any U-joints. It has CV joints on
both ends of the axle halves that transfer power from the differential
to the wheels.
I would think if there were a problem with the cv joints, you'd know about
going around a corner or shifting from park into drive, but that's just a guess.
My guess would be something internal to the transmission.
ericdude is offline   Reply With Quote
Old 06-01-2009, 08:19 PM   #3 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316600
View SCT's Photo Gallery
AE92
Yea, it's the tranny. My auto, when it used be, had that problem. Sometimes it would go into reverse smoothly then sometimes it would shock the entire car.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 06-02-2009, 09:31 AM   #4 (permalink)
so you're saying it's the entire tranny or would it be a particular part?? I'm looking around my local area to see if any tranny places have free diagnostics
there doesn't seem to be any problem going around corners or going from park to drive. It's going from drive to a complete stop, then reverse and then you hear the clunk
Old 06-02-2009, 09:57 AM   #5 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
whens the last time you changed your transmission fluid? have you checked the level? it might be low.
'81 BMW R65
Old 06-02-2009, 10:09 AM   #6 (permalink)
had it flushed at the last 6k mile service. I periodically check the level and it's never gotten seriously low
Totaled 1996 Corolla DX
2009 Nissan Altima 2.5S with Takeda SRI, stock dual exhausts, mesh grille
LED bulbs for dome/map/turn signal/tail light/3rd brake light/back up bulbs
Old 06-02-2009, 12:00 PM   #7 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
What is your idle speed?
Have you checked the engine/transmission mounts?
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 06-02-2009, 01:51 PM   #8 (permalink)
Ugh. Change fluid good, flush bad. Some crud might have been forced
into your valves. At least, I've heard bad things about shop flushes.
Old 06-03-2009, 12:53 AM   #9 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
I would also say motor mounts, most likely worn out making the engine have that extra kick when it goes in reverse... some motors do it going into drive also.
Old 06-03-2009, 12:24 PM   #10 (permalink)
well I've scheduled to have a free diagnostic external check with Aamco and see what they say and I'm also going to have it checked by other AAA approved centers that also provide free diagnostic checks to see what it really is. Hopefully it's not that bad of a repair
Old 06-04-2009, 01:29 AM   #11 (permalink)
KDM is in
REN69's Avatar
Aamco will want $2000 to rebuild a transmission that you can find used for $200... don't bother.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 06-04-2009, 11:40 AM   #12 (permalink)
well I probably won't go to aamco for that...just want to see what they diagnose and say what the problem is.
A friend said about the similar price for a cv boot job if I order from a local wholesale car parts place and then have it installed by his wife's dad.
Old 06-08-2009, 06:49 PM   #13 (permalink)
well I took my car to aamco and several other auto tranny places and they all said that the transmission is fine. It's the engine mounts that need to be replaced, but since the car is old, it's probably not worth it to repair, so I'm going to see about how much junk yards will buy it for parts.
Old 06-08-2009, 07:16 PM   #14 (permalink)
Donald's Avatar
You are kidding, right!?
How much did they estimate for the replacement of the mount?
The junk yard will probably give you $100-150. You can sell it on the street for a bit more. Just let the buyer know it needs engine mounts. If you were near me I'd buy it from you.
Old 06-09-2009, 09:30 AM   #15 (permalink)
well some of those places said the parts are a few hundred. I was able to find engine mounts from an online place that I bought an exhaust manifold from when they advertised on ebay and those engine mounts were much cheaper, but that's just the parts...have to factor in the stupid labor charge.
So I think I might just take it to a junkyard or if a friend wants to buy it, will have to sell "as is".
