replace ignition in 92 corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2009, 12:51 AM   #1 (permalink)
Cuwee's Avatar
View Cuwee's Photo Gallery
i need to replace the ignition in my 92 corolla bc it doesnt work right and mi key falls out. how do i replace it?
Cuwee is offline   Reply With Quote
Old 06-02-2009, 01:12 AM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
I've never done it on the corolla but I did it on another car before, you should be able to access it by removing the steering wheel shrouds (panels) once you remove that you'll have access to the actual cylinder.
Best thing to do, find one at the junkyard and figure it out by removing that one first... THEN go home and remove yours.
Old 06-02-2009, 12:13 PM   #3 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
I believe the switch/lock is held on by special bolts that the heads break off when they are tightened.
If my memory is correct, you will need a needle point vicegrip pliers and some patience to get them out, or drill and easy-out.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
