Idle w/ AC On, 4AF - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-03-2009, 09:39 PM   #1 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316600
View SCT's Photo Gallery
AE92 Idle w/ AC On, 4AF
Anyone know how to increase/ decrease the RPM for the idle that the A/C controls? My idle goes through the roof when the car is at idle. I don't think it needs to be THAT high, like 2k-2500 RPM when in neutral (its a M/T)...
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 06-05-2009, 04:45 AM   #2 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Check out the throttle positioner on passenger side of carb. It is a dual diagram unit with three vac hoses and two adjustment screws. Look at unit with a/c off and then have someone turn on a/c and see which cam moves to determine which adjustment screw to turn. I don't have a diagram to post so you will need to consult a service manual for more detailed info.
90 GP is offline   Reply With Quote
Old 06-06-2009, 07:59 AM   #3 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
look at the unit in the very rear of the passenger side. Don't mess with the other one which is just in front of that. It has an upside down lever which gets pushed into the bottom of the diaphram lever. idle should be about 1k or so with a/c on.
1989 Toyota Corolla SR5, Carb.
1993 Camry LE
retiredat44 is offline   Reply With Quote
