weber install... not going to plan - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2009, 01:05 PM   #1 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
Ok, so I tried to install my weber 38 the other day on my SR5 (4AF)... and it didn't go quite according to plan
I was posting in the 4AF intake mod thread, but I decided to make my own thread and stop jacking that one
other thread: Intake mod for 4AF carb
Ok, so to bring everyone up to speed, I installed my weber and now my car won't start. It has spark, and I pulled the plugs and they were dry... so there is a fuel problem.
I just tried to spray starting fluid in it and it'll start for a little bit and then die. One time it started and ran for probably 30 seconds and then eventually started knocking pretty bad and then died again... I tried turning the mixture screws out more, but it didn't really help any.
when it ran for 30 seconds I had just changed my FPR to 5.5 psi instead of 2... to see if that was a problem, I'm not sure if that's why it ran so long though.
why would it be knocking so bad? and why won't it stay running?
Is it possible I got a bad carb?
'81 BMW R65
Old 06-09-2009, 09:34 AM   #2 (permalink)
Rotary guy...
eage8's Avatar
So I finally got it running and drove the 3 miles to work today
my FPR is at 5.5 psi and the mixture screws are at 4 turns... I think something is wrong :-P. I think I might call weber up soon.
it's also idling at 2500...
'81 BMW R65
Old 06-09-2009, 09:10 PM   #3 (permalink)
View kcwa's Photo Gallery
What I think "might" be the problem is that you need a fuel pump that can properly supply the Weber...or you do not have jets that are properly sized for the 4AF. There are others out here that are much smarter than I...they will know.
1990 Corolla SR5 Coupe 4AFE 5-speed
"Gentlemen, you can't fight in here! This is the War Room!"
~ Dr. Strangelove, 1964
kcwa is offline   Reply With Quote
Old 06-10-2009, 08:37 AM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Thats alot of turns, 2-2½ should be enough.. I only tuned a set of DCOE webers, so I cant help here.
Old 06-10-2009, 10:11 AM   #5 (permalink)
Rotary guy...
eage8's Avatar
yeah, I've been emailing back and forth with weber (they actually have really good support). The current ideas of what might be wrong are either:
1) linkage binding
2) big vacuum leak
3) fuel obstruction
I haven't had time to mess with it though since I talked to them.
'81 BMW R65
Old 06-10-2009, 10:12 AM   #6 (permalink)
Rotary guy...
eage8's Avatar
yeah, they're supposed to be around 1 turn and the psi is supposed to be at 2 psi...
'81 BMW R65
Old 06-10-2009, 09:06 PM   #7 (permalink)
View Theron's Photo Gallery
How does the Car act with the 38?
Now you need some Web Cams. a wideband o2, and your set
1989 Corolla DX with rebuilt 4-AF
Theron is offline   Reply With Quote
Old 06-11-2009, 11:08 AM   #8 (permalink)
Rotary guy...
eage8's Avatar
right now, it barely runs lol, so not very well... But according to the weber guy it "should feel like a 2.0L or a small v6" lol and have twice the torque increase as the 32/36 so we'll see...
I'm tempted to borrow the wideband from my rx7 to see what it's doing later, but right now I don't need a wideband to tell me it's pig rich.
'81 BMW R65
Old 06-14-2009, 06:36 PM   #9 (permalink)
Rotary guy...
eage8's Avatar
yay! I got it to work right.
there were 2 problems.
a) there was a small vacuum leak that fixed itself when I took off the carb and put it back on friday night.
b) I had a faulty fuel pressure regulator (lame), I went and got a slightly nicer one that looks exactly the same but is a mr. gasket one instead of a spectre one. It has metal fittings instead of plastic ones
so it runs pretty well now, but it made my car sound like a civic
I'll write a full right up later, maybe tomorrow, that tells you where to run vacuum lines and such.
'81 BMW R65
Old 06-15-2009, 03:09 AM   #10 (permalink)
xhiphop2flipflop
rwalsh.ae92's Avatar
View rwalsh.ae92's Photo Gallery
good job, man, i can't wait for the write up.
im so doing this to my 4af.
how's it pull??
rwalsh.ae92 is offline   Reply With Quote
