4af white spark plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2009, 12:15 AM   #1 (permalink)
View toyota4x4$'s Photo Gallery
i got a 89 corolla sr5 4af motor. i changed every fluid and filter on the car and changed the spark plugs. when i changed the spark plugs i noticed that they were white. so i changed them again 3 months later and they were white again. i changed them again to a lower heat range plug and it still didnt do anything. i changed the timing to 5 degrees btdc. i cheked the codes the other day and it read no stored codes. the car runs not bad, but i feel its running lean by the way the plugs look. any help is appreciated. iain
toyota4x4$ is offline   Reply With Quote
Old 06-10-2009, 07:39 AM   #2 (permalink)
View kcwa's Photo Gallery
Could be that you are running lean or the timing is advanced...but what I am thinking is that the plugs you are running might be too hot and you need to use cooler plugs. What plugs are you running? Could be a combination of all three...
1990 Corolla SR5 Coupe 4AFE 5-speed
"Gentlemen, you can't fight in here! This is the War Room!"
~ Dr. Strangelove, 1964
kcwa is offline   Reply With Quote
Old 06-10-2009, 08:38 AM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Unleaded fuel makes plugs whitish. BCPR527Y should be the correct plug, no need to go to a different heat range, hell, I run 5's on a turbo corolla :P
Old 06-15-2009, 06:50 PM   #4 (permalink)
i did change the plugs to a cooler heat range and i changed the timing to 5 degrees btdc (stock). and it still didnt do anything. im takin it to a auto shop tomorrow and gettin them to diagnose it., so i can fix it at home.
Old 06-22-2009, 08:09 PM   #5 (permalink)
turns out the plugs were fine according to the mechanic, he said that the car was suppostu run a little lean for added horsepower?? he said that they were not that bad and i had nothing to worry about.
Old 06-22-2009, 08:51 PM   #6 (permalink)
That is good to hear... at least I was kinda correct about running a little lean. Sounds like you are good to go!
Old 06-23-2009, 02:11 AM   #7 (permalink)
Resident asshole
Flashmn's Avatar
wait what... a little lean eh? no way man, horsepower is made slightly rich, but its normal for the plugs to be white when using unleaded.
Old 07-07-2009, 12:56 AM   #8 (permalink)
enginemount
enginemount's Avatar
View enginemount's Photo Gallery
Maybe there just a little vacuum leak, in carb engine case, vacuum leak cause the venturi flow down and less fuel atomization.the normal vacuum should be more then 20 in/hg (mine is 23in/hg) , you may check the hoses or devices about the intake manifold & carb.
enginemount is offline   Reply With Quote
