Will these Celica wheels fit? (I know...shoot me >.>) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2009, 04:39 PM   #1 (permalink)
Rawr!
aHarmony's Avatar
View aHarmony's Photo Gallery
Sorry in advance...I know it's probably buried somewhere in the forums...did a search for 'celica wheel' and turned up nothing.
Someone locally is selling a set of '88 Celica mags + tires and I'm really tempted to snatch em up because I don't really care for 16-17" rims.
I know the 4 bolt pattern matches, but is there anything else that will determine whether these will work on my '88 Sedan? I have a feeling it's okay since it's the same year and Toyota, but if someone has a clue it would be really helpful! Thanks
Oh, here's a pic...
Cars - '88 Corolla DLX Sedan (4-AF)
aHarmony is offline   Reply With Quote
Old 06-10-2009, 05:59 PM   #2 (permalink)
boopie's Avatar
View boopie's Photo Gallery
Looks like a 4x100. I think it will fit. You'll never know till you try it
boopie is offline   Reply With Quote
Old 06-11-2009, 01:58 AM   #3 (permalink)
Rawr!
aHarmony's Avatar
Well, for $80 for the whole set with tires I don't think I can go wrong...I'll post back with my findings
Old 06-11-2009, 02:00 AM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
YOu sure those are Celica wheels? I don't recall Celicas coming with 4-bolt wheels unless it was the earlier models up to 85 and those were 4x114.3 bolt pattern.
Test fit before you buy, or you'll end up with a set of wheels you can't use.
Old 06-11-2009, 02:08 AM   #5 (permalink)
Rawr!
aHarmony's Avatar
Yeah, as far as I know they are Celica wheels.
You're probably right now that I research it...Celicas and Celica Supras of that year range came with 114.3 x 4 bolt patterns, not 100 x 4.
I'm really new to wheel sizes. 100 x 4 means it's a 100mm bolt right? So that would mean that they simply wouldn't fit because my bolts on my car aren't long enough...right?
Yeah, maybe it's not such a great idea. Ah damn, they're nice lookin too
Old 06-11-2009, 05:55 AM   #6 (permalink)
YYYOOOOUUUUHHHHHHHOOOUUU!
Rookie_One's Avatar
View Rookie_One's Photo Gallery
in fact the 100 refer to the distance between the bolts if i remember, dont remember WHICH distance thought
Rookie_One is offline   Reply With Quote
Old 06-11-2009, 09:00 AM   #7 (permalink)
AE92 3SGTE
View erixon's Photo Gallery
haha, that would be wicked if they had 10cm bolts... I don't think there would be room for 4 though.
erixon is offline   Reply With Quote
Old 06-11-2009, 10:14 AM   #8 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
The 4x100 means there are 4 bolts and they are set around a 100mm circle (at 90deg increments). The measurement is from the center of one stud to the center of the opposing stud.
If the lug spacing is correct, you still need to make sure the offset is compatible.
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 06-11-2009, 11:06 AM   #9 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
Most of the time you also need to make sure the center bore of the wheel is the same if not bigger than the bore of your hub (the center circle)
luckily corollas have the smallest center bore I know of at 54.? mm so everything fits on them
'81 BMW R65
Old 06-11-2009, 11:49 AM   #10 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Very good point. That's why, for instance, Civic wheels fit on Corollas but not vice versa (IIRC).
Old 06-12-2009, 11:26 AM   #11 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
celicas 86-91 could have had a 4x100 lug pattern. the st and gt models 86-89 had that pattern and 90-91 ST had that pattern. prior to 86 it was 4x114.3 and the higher end models 86-91 had 5x100 and after 92 they all became 5x100.
center bore should be the same for the corolla actually.
I dont imagine you would have a problem with offset, the suspension 86-89 is practically the same for the ae92s (a lot of part numbers even cross over like coil springs).
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 06-12-2009, 12:55 PM   #12 (permalink)
View 92MX83's Photo Gallery
Yeah, that is from the lower trim level Celica, ST162 I believe. It was the first FWD Celica. The wheel should have no problem fitting, since the center bore should be identical among all Toyota passenger cars of that vintage. The wheel also is probably very skinny, likely 13x5" or 5.5", and should have the typical Toyota FWD high offset. Are you sure you want to stick with 13s? At any rate, these aren't gonna rub, if that's what you're worried about.
"Crush enemies, see them driven before you, and hear the lamentation of the women!" - Conan the Barbarian, on what is good in life
92MX83 is offline   Reply With Quote
