Was looking through Toronto kijiji Friday and stumbled upon this little gem, called and went to pick it up saturday. For $1000 score!
The good:
2nd gen Silvertop w/c52
ACT clutch 6 puck sprung disc w/ pressure plate
All piping fairly well done
Braided line with jic fittings for remote oil filter and water lines for turbo
Almost brand new Garrett gt2554r ball bearing turbo, list price $1100.00
Wiring done properly runs good till boost comes on
2.5" stainless catback, no mufler though
Came with but not installed apexi turbo timer and afm converter
trd quick shift kit
turbo manifold stainless and well built
momo race wheel(although blue) with hub
ground control coilovers with eibach springs, kyb struts
had a recent brake job with e-brake cables
Car is a 1990 gts so better pattern interior and nicer door panels
has working sunroof
The ok:
Motegi mr7's with good rubber
some cheap aftermarket buckets but comfortable
The bad:
car does run well but the shop that did all the work didn't tune the engine at all, no rising rate, stock wastegate @ 10psi way too much, stock gts fuel pump
2 1/4" downpipe with 2 1/2" catback. Don't know what they were thinking here
when boost hits blows smoke bad, and smokes very little at idle as well
no oil cooler
wing
painted interior
dash cutout for gauges that were non-functional
car is fairly clean but does have some rust on the rear 1/4's and as usual the sunroof panel
was in a accident at some time, hit on drivers front corner not the best fix
don't have the wheel locks so will have to drill them out
neon lights everywhere
rear portion of exhaust
Had a bomex body kit but front and rear bumpers got damaged by a pothole so I was told
side skirts are molded to the rockers
Car will be my dads as he loves these things, so will return to stockish and if the compression checks out will run the silvertop in n/a form. I'm hoping the 10 psi didn't kill the rings but would explain the smoke as there is no oil in the charge pipes the turbo does have a proper oil restrictor in line. Turbo is going on the sedan.
Just a thread to bring her back alive hasn't been plated since 2005.
