i think the wirings going to be a bit different since he probably has a bluetop. coolant lines and everything will match up though as long as you keep your old block and head for random sensors and parts. if you have a bigport redtop you could reuse the tvis manifold and i think thats all you need to convert it to fwd
personally if all you did was bent a valve id take his head and swap it onto yours. it'll save you a lot more time and hassle. if you're feeling ambitious you could pull off the oil pan and do the bearings and rings
Oh, I guess I should have mentioned... I have a 4A-F in there now. I don't think the coolant lines are close to the same as the AE92 4A-GE, so I don't think I could mount them to the old 4A-GE.
is the thermostat even in the right place?
this is from an '86 AE86
'81 BMW R65 For Sale: GT-S strut bar + Front GT-S koni yellows
do my 4A-F pistons have the same compression as the 4A-GE pistons?
They are pretty close - I believe the specs are 9.5:1 on the 4A-F, same as the 4A-FE I believe, the 4A-GE can be had with a 9.4:1 ratio for the earlier models, the later ones had 10.3:1 ratio (smallport). Assuming all US spec'd engines.
not sure about the compression but yeah if you have a 4af you might want to grab a gts radiator and coolant lines. if you're going from a 4af im pretty sure you're going to need his computer as well, it'll be a pretty big job
yeah, I'll also need an EFI fuel tank + pump and a fuel return line...
I might just go get another 4AF head from the junkyard for $40
basically if you have an ae86 complete LB, manifolds, and wiring -- sell it to an ae86 guy.... it's all 100% useless in an ae92.
you will need all of the FWD (or MR2) pieces.... only the LB is the same (trust me I know... I have an ae86 LB in my wifes aw11). None of the cooling pipes/locations are in the same spot -- not even the radiator is the same. T-stat pipes on mr2/fwd's are in an external housing mounted on the transmission unlike in the side of the head like the F heads.
also -- the 4af/4afe has lower compression -- but the pistons are not the same.... In order to (first) find out what pistons you have you would need to pull them from the 4afe.... A series motors have 2 sized pins, 18mm and 20mm.... most 4age are 20mm, but since it's from an ae86 it would depend on year -- the early 4age's had 18mm.
compression on these is more than just the piston.... you can't take a 4age piston and put it in a 4afe block/head and expect the compression to be the same.... the combustion chamber sizes between a 4afe and a 4age are different, hence a different compression. 4af/4afe pistons tend to be more dished (like a gze piston.... but don't get them confused as gze pistons are coated and semi-forged) and ge pistons are either flat or more domed (depending on the generation).
you can do it with a 4afe ecu.... and modify the ecu (along with wiring to take a 4age dizzy... which you then have to find the uber rare JDM map 4age dizzy).... but in terms of practicality doing a wiring swap would be easier.
if you had a 4af you will also need an efi pump.
