i heard there was a guy on here that can make me a custom harness. i need to wire my 4age 20v silvertop to my 1988 corolla sr-5. the engine is in. ive already put in the gas tank, fuel pump, new motor mounts the old ones were worn to hell. well here are pics of my ae92 for your viewing pleasure. its dirty and engine isnt wired but the car is getting there
Both these guys can get it done properly for you. Or if you were to find a complete 90-91 corolla gts harness it almost plugs in with the silvertop harness. This is using a 2nd gen silvertop, not sure how a first gen would work out, might be the same.
i think this is the same guy to. but at almost $600. ill just pay the shop they are charging me $400. but thanks it was def worth checking out. if i had the money i would do i like how clean it looks
how did you manage that, yota engines dont bend valves, unless you have longer duration cams or something like that
Nice car man, keep its outer appearance low-key and you should be blowing peoples doors off in no-time, you can hit up club4ag.com for wiring diagrams if you want to attempt this yourself, if not dr.tweak is the guy you wanna talk to
Hazarding a guess about eage8: he probably over-revved it, probably from a missed shift. Heck, I'll even guess specifically that it was 2nd to 1st. Am I right?
Whose doors can you blow off with a 16-17 second 1/4 mile? Or is there something I don't know?
Most dyno's I have seen of bone stock silvertops are around 135-140ish to the wheels with a healthy motor. So a good running silvertop with a c52 or c56 in a 2300lbs car with a good driver should be able to pull off high 15 sec passes.
I was actually at his house not that long ago dropping off a harness for a friend. I don't think he comes on here much anymore.
And the second part of your comment has me lost. even if he has a uncut silvertop harness he will still have to cut and paste to the 4af interior harness. He needs power/grounds and to wire up a fuel pump relay since he was running a carb before.
he over-revved it cuz he recently did a weber carb upgrade. guess imma rethink that one, aye eage8? haha. man, i've been thinking bout this swap since ive had my 'rolla
