Where are the 4WD manual tranmission drain and fill plugs? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-20-2009, 03:02 PM   #1 (permalink)
View Psamtik2002's Photo Gallery
Hi guys, I just got a 4wd 89 station wagon for free. I figure I'll do some maintanance on it and then sell her. Does anyone know where the manual transmission fill plugs are? The owner's manual only lists automatic (grrr)
Thank you
Psamtik2002 is offline   Reply With Quote
Old 06-20-2009, 09:57 PM   #2 (permalink)
View BugDiddy's Photo Gallery
the drain and fill plugs are the biggest ones (26mm). the fill plug will be facing the front of the car. you can see it from top of the engine bay if i remember right.
the drain plug is further back and faces the drivers side of the car. its near where the control arm bolts onto the frame.
they stand out once you look for the 26mm size because its so large
also be sure to use API GL-4 80w90 gear oil
BugDiddy is offline   Reply With Quote
Old 06-21-2009, 07:27 PM   #3 (permalink)
Thanks! I found three 26mm drain plugs. Do you know where the fill plug for the center differential is?
Old 06-22-2009, 12:17 AM   #4 (permalink)
the transfer case shares the same fluid with the transmission. I don't remember seeing 3 26mm bolts on mine, but I will take another look tomorrow since I'll be down there anyway.
Old 06-22-2009, 05:42 PM   #5 (permalink)
^ Drain Plug
^ Fill Plug
^ What it looks like when you get under there
Also an obvious reminder- crack the fill plug before draining... just in case it decides to strip, break, or just won't come loose.
Old 06-23-2009, 08:51 AM   #6 (permalink)
Thanks for the pics! I learned the hard way before to take the fill plug off first on my Prism differential. Scared myself that I had permanently disabled that car until I found a way to take it off. The the third drain bolt I was talking about I found on the passenger side, facing the ground. I also found a 10mm hex bolt on top of the tranny, but it was on so tight I couldn't get it to move at all. Do you know what that could be for?
Thanks!
Old 06-23-2009, 01:02 PM   #7 (permalink)
1990 Corolla GTS 4A-GE
Createdtoburn's Avatar
View Createdtoburn's Photo Gallery
lol dont take the 10mm bolt off. You prob need it to hold your shit together. :-p Fill and Drain plugs are usually the same size and they're much larger then all the other bolts and just kind of obvious looking.
Createdtoburn is offline   Reply With Quote
Old 07-29-2009, 10:30 PM   #8 (permalink)
View 89corolla4wd's Photo Gallery
just to clarify. The transfer case does have its own drain plug but is filled with the tranny fill plug since they share the same fluid correct?
89corolla4wd is offline   Reply With Quote
Old 07-30-2009, 01:15 AM   #9 (permalink)
View datsa's Photo Gallery
I believe this is correct for the manual transmission only: the transmission and the transfer that is posterior to it both have their own drain plugs, but these cases are contiguous with each other so that anytime you fill the transmission case you are also filling the transfer (front & center differential).
Here is a top-view of the manual transmission:
Here are some exploded transmission diagrams.
You can also try this page www.alltracwagon.net
1988 Corolla SR5 AE95
datsa is offline   Reply With Quote
Old 07-30-2009, 02:56 AM   #10 (permalink)
My Toyota shop manuals recommends API GL-5 for the transmission and differentials. Interesting . .
