Engine Oil Pan Bolt Torque - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2009, 11:12 PM   #1 (permalink)
View ericdude's Photo Gallery
I noticed some weirdness between the factory manual and the Haynes manual for my '88 4AF
with regard to the oil pan bolt torque.
The factory manual says the torque is 43 in-lbs, just like the tranny pan bolts. However, the
Haynes manual says that it is 90 in-lbs (for the 4AF) and 48 in-lbs for the 4A-C/4A-GE.
OK, first of all, I thought the 4AF(E) and 4A-GE had the same cylinder block, and only
differed in the cylinder head, which should mean the pan bolts are the same. The 48 in-lb
figure looks like a typo or misread of 43, but the 90 is just way, way off.
Anyone sort these numbers out before? Is the block aluminum? If so, I can understand it
should have the same torque as the tranny pan (tranny body is aluminum). If not, seems like
torque should be higher. I am high on crack for even questioning the factory manual?
ericdude is offline   Reply With Quote
Old 06-22-2009, 11:22 PM   #2 (permalink)
1990 Corolla GTS 4A-GE
Createdtoburn's Avatar
View Createdtoburn's Photo Gallery
Shit, I just replaced my oil pan gaskets on Saturday and I hand tightended them down to a fairly good amount without stripping them. No problems on my side, or leaks. :-) BTW, it's a bitch job to do haha. Luckily I work in a shop so it was a lot easier, it helps if you take off both skid plates, and the exhaust pipe piece that runs right under the pan, then just drop down the K-member right below it so you can get to the back bolts. Not too hard over all, just takes a bit of time. Lots of 14mm, 16mm, 10mm bolts.
Createdtoburn is offline   Reply With Quote
Old 06-23-2009, 12:45 AM   #3 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
Off the top of my head, I believe the 3S torque is 48 in-lbs (4 ft-lbs). If you use the Toyota FIPG, you don't need it to be very tight.
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
