Sedan Tail Lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-07-2009, 09:06 AM   #1 (permalink)
G Man
View xxgmsmgxx89's Photo Gallery
Sedan Tail Lights
So, this weekend i was prety bored so I decided to take out that ugly yellow turn signal plastic from the tails. It was easy, the result is pretty nice. instead of having just white incandescent bulbs flashing, though, i decided to go with LED blinkers (mad JDM, right? lol) After adding the resistors (they blinked too fast when i put the bulbs in) it looks sick. i also put in some LED's in the headlights, just for looks...they dont actually project any light. heres some pics.
xxgmsmgxx89 is offline   Reply With Quote
Old 07-07-2009, 02:54 PM   #2 (permalink)
Mugen's Avatar
View Mugen's Photo Gallery
Wow that looks really nice!
Mugen is offline   Reply With Quote
Old 07-07-2009, 03:06 PM   #3 (permalink)
G Man
thx, altogether, including oven baking time, this took me about 30 min
Old 07-07-2009, 05:30 PM   #4 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
I'd say just throw in some 1156NA bulbs(amber OE style) and call it a day. but thats just me
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 07-07-2009, 07:00 PM   #5 (permalink)
1990 Corolla GTS 4A-GE
Createdtoburn's Avatar
View Createdtoburn's Photo Gallery
Damn, I want to do that to my car now. How exactly did you do that?
Createdtoburn is offline   Reply With Quote
Old 07-07-2009, 09:18 PM   #6 (permalink)
View jkittre777's Photo Gallery
Very nice. More info please
jkittre777 is offline   Reply With Quote
Old 07-08-2009, 03:07 AM   #7 (permalink)
'Rolla NiNJa
hollowreaper13's Avatar
View hollowreaper13's Photo Gallery
DIY if you can please
hollowreaper13 is offline   Reply With Quote
Old 07-08-2009, 08:58 AM   #8 (permalink)
G Man
I will be taking pics later when I get home, or on my lunch break today, and ill add them to the appropriate steps...dont worry, i know pics say a thousand words lol
BTWWWWWW im not 100% sure but this only works on Sedan, i think the coupe just has a yellow lens, not a clear lens with yellow behind it. you can actually feel/move the amber plastic, it kind of unclips if you press on it from inside the trunk with the white lamp holder removed, but it cannot come out from there, you do need to follow these steps:
OK, well in order to get the light assembly off, you need to:
1) Unclup the wires off the light assembly bolts. they should be little beige clips that have a loop that the wire goes through. They just pull off with little effort. If you have to, just pry em off
2) a 10 MM socket (iirc) removes the 4 bolts on either lens cover.
3) It is wise to do this on the hottest day possible, as the assemblies are black glued to the body, not just fitted, so you really have to push from behind and use some sort of plastic prybar or something on the outside lip and get the lights off...the glue will stretch for about a foot (at least it did when I did this in 89 degree weather) and dont worry, these are pretty tough so dont be afraid to use some POWAAA
4) once the lenses are out, and there are two nasty, gooey holes in your car, unscrew the 3 little phillips head screws in the middle of the lens holding on the black plastic line that separates the reverse light/blinker and the brake lights. *the screws are on the inside of the assembly
5) ok, now that the lights are out (dont forget to unclip the white lamp holder off the back of the lens!) get your apron on, cuz its time to bake. i didnt preheat the oven or anything, i just put em in cold then turned the oven on to about 200 degrees. let them sit for about 5 min, take them out, and, without burning yourself try to start taking off the black line starting on the side that would be closer to the middle of the car (if it seems impossible, put them back in the oven for a few minutes) . the black strip is "slid" into the outside, then it sort of just lays into the middle. theres glue holding this in, so make sure the lights are hot enough so that you dont break the strip because of cold glue.
6) Now, its all about getting the reverse/blinker lens off. I just used a flat head (of course i chipped the edge of the plastic, so be careful) and gently pried off the clear from the black. Its very easy to crack or chip the clear, so make sure you DONT focus the prying on one spot of the lens, after a little playing around it should be a little easier to just pull off by hand. again, though, make sure you dont crack it by pulling it off like I did lol
7) This step is obvious, just take out the nasty amber plastic. (no pic lol)
8) i put everything back in the oven for a minute to warm the glue up, I have heard that reheating the glue too much ruins it so I only put them in the oven for like 2 minutes @ 200 degrees. Then, press (with a towel or something with the light assembly on a soft surface, like another towel) the lens back on and immediately after put the black strip back in, starting with the outside of the lens. this has to be done quick, or else the strip would look like it was removed. Then, replace the 4 little phillips screws so they pull the strip back on, flush. Then, put the lights back in the car holes, replace the bolts that go on the studs (These studs are very fragile, i slightly over tightened one bolt and the stud just twisted off with it) but tighten them enough so they are flush again. make sure the glue is somewhat neat looking on the car body, as it would look kinda crappy if the glue is bulging out of the seams. after, just make sure theres no leaks, and then presto, your done. dont forget to reclip the wires on the bolts.
like I said, ill take some pics later, not sure if im taking pics of the glue and all that, but its pretty simple. any questions, please PM or ask on here.
Old 07-08-2009, 09:03 AM   #9 (permalink)
G Man
im a total cheapo, anything i can do without paying for / found in my tool box, ill do. this costs 0$ lol
for the front lights, i just removed the entire grill/lamp assemblies (including the "pointing cage" thats bolted to the lens) and used those little stick-on led lights and stuck thm to the red filler bar that runs under the lights/grill...they come in 12 and 15" strips @ autozone. i used 15" white LED's, then used black elec. tape to tape off the lights that werent directly under the clear lens. i hooked the LED's to the corner lamps, so they go on with the P lamps and the head lamps. they look cool @ night with just the LED's. any q's about that, let me know !! im here @ work bored all day, so keep me occupied lol
Old 07-08-2009, 02:21 PM   #10 (permalink)
You should post a picture of what you mean xxgmsmgxx89
Old 07-08-2009, 03:29 PM   #11 (permalink)
G Man
ill take it apart later and take some pics...
Old 09-28-2009, 01:01 PM   #12 (permalink)
BORICUA
jungobaez's Avatar
View jungobaez's Photo Gallery
Im waiting for the pictures of ur last post.
Edwin "Jungo" Baez
jungobaez is offline   Reply With Quote
Old 09-28-2009, 08:34 PM   #13 (permalink)
View 1991corolla4afe's Photo Gallery
Anybody know if this works on the center license plate piece too?
1991corolla4afe is offline   Reply With Quote
Old 12-01-2009, 03:07 PM   #14 (permalink)
G Man
hey, thanks for sticky...this is my first sticky yay me lol
Old 12-01-2009, 03:09 PM   #15 (permalink)
G Man
and oh yea, about that last post...i dont feel like taking it all aart again (even though the pass. side led's are not working, gotta replace them because the wire that comes out of the strip of lights has snapped right at the end of the strip, so no cut/splice routine going on here...) but let me find some pix of the front and ill point out what u gotta do...gimme a day or so to dig up those artifacts
