Carburator Issue I guess - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-10-2009, 04:46 AM   #1 (permalink)
View jinantha's Photo Gallery
Hi,
I have a 1992 Toyota Sprinter Station Wagon. Engine type 2E. 4 forward Manual. Model EE106V.
When I change gears, during the clutch down and when i take my foot off the accelerator, engine vibrates and tries to stop. so after the gear change when i accelerate, engine vibrates and pickup speed.
even when the A/C is on Econ mode, when the compressor goes on and off (specially off) the engine does the same thing. vibrates, is like the idle is not good.
Anyone have a clue?
jinantha is offline   Reply With Quote
Old 07-10-2009, 01:06 PM   #2 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Could be carb, timing, or a vacuum leak.
I would start checking for a cracked or broken vacuum line first.
Next I would chech ignition timing, then carb adjustment.
If all that fails, you might need to clean the carb.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
