oil leaks NEed help asap on my ae92!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2009, 07:12 PM   #1 (permalink)
View joevanni's Photo Gallery
Unhappy oil leaks NEed help asap on my ae92!!!
hi guys im a newbie to this forum but i need ur help i got a oil leak problem and need help asap i got a 1988 toyota corolla gts fwd and the front of the engine is leaking oil bad i just replace the front main seal oil pan gasket, and the cam seals.I also replace the rear main seal but on the front of the engine is still leaking oil bad it looks like is coming from the cam seals but i just replace them and i took them off just to make sure they werent defected but they are fine i dont know what else could it be can anybody help me please i need the help asap.
joevanni is offline   Reply With Quote
Old 07-15-2009, 01:17 AM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
could be leaking oil from the distributor area, very common on the 4AGE motors.
Also make sure that your oil cooler lines are ok and not rusted, even the clamps, I had problems with those before.
Old 07-20-2009, 03:01 AM   #3 (permalink)
View teamyoda's Photo Gallery
AE92
ren69 is right. I recently replaced the valve cover gasket and sparkplug tube seals. there was still oil on the top of my tranny. you might wanna take your air filter or airbox off so you can get a better view of where the oil is coming from. my friend has a 91 4door. 4aFe it had that exact problem. it was leaking from the seal that holds the oil from coming out the distributor port.
teamyoda is offline   Reply With Quote
Old 07-23-2009, 06:36 PM   #4 (permalink)
View CelticKrozz's Photo Gallery
My 88 SR5 4af has an Oil leak and I used a cheap UV dye to locate it 1 bottle and 15 mins later I found it leaking from the Crank oil seal and Oil pump gasket area and for 14$ I got a complet gasket kit that has pump/puller gasket, O-ring for dip stick and Crank seal
the dye works great if your engine its all that clean like mine is
CelticKrozz is offline   Reply With Quote
Old 07-23-2009, 06:59 PM   #5 (permalink)
yea. when I bought the car it was so dirty. I couldn't stand it. the first thing I did was use some black magic spray and cleaned the whole thing. you could eat dinner off my valve cover.
'91 Corolla sr5 4age - soon to be 4aGe 20vBT
Old 03-25-2012, 11:06 PM   #6 (permalink)
Risforrawr's Avatar
View Risforrawr's Photo Gallery
i also have an oil leak and pretty bad i havent had a chance to look into it , just noticed it the other day . and i hope its nothing too serious cause then its game over for my sr5
who dah fawwck?
Risforrawr is offline   Reply With Quote
Old 03-26-2012, 04:57 AM   #7 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
If your oil pressure sending unit is located in the vicinity of your leak that could be the culprit.
90 GP is offline   Reply With Quote
