thanks to all who helped me with 92 corolla,
did the adjustment of tps and cleared the code,ran smooth for about
3-5 minutes, then started to stutter again
and threw a new code 71,which i believe is egr?
i pulled to vacuum lines that lead from firewall to brass sensor/valve
that has a white plastic adjust screw,spring tensioned
that connects to the egr valve,what part is this one.
when i pulled lines,engine idled smooth again,couple minutes later
started idle changes.
i guess i can slowly replace every part on engine until is new
anybody have any ideas,anybody?
thank you
32621
