will this spoiler fit? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2009, 02:37 AM   #1 (permalink)
'Rolla NiNJa
hollowreaper13's Avatar
View hollowreaper13's Photo Gallery
will an 89 ae92 gts stock spoiler fit on a 90 corolla sedan? thanks
hollowreaper13 is offline   Reply With Quote
Old 07-28-2009, 04:56 PM   #2 (permalink)
'Rolla NiNJa
bump
Old 07-28-2009, 05:38 PM   #3 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
I think so, but that is just a guess. The worst that it could need is the ends trimmed off if it doesn't fit.
I believe it will though.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 07-28-2009, 05:41 PM   #4 (permalink)
'Rolla NiNJa
well i'm just concerned that the drilling points on the spoiler will overlap the trunk lid, so i won't be able to open the trunk
Old 07-28-2009, 05:48 PM   #5 (permalink)
Donald's Avatar
My GTS trunk lid is 48 3/4" right at the rear most edge, 49 3/4" with the tape measure just before the spoiler outer legs. The spoiler outer legs are about 5/8" from the edges of the trunk lid.
I hope that helps.
Old 07-29-2009, 01:52 AM   #6 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
I'm 60% sure it would... looking at the GTS spoiler you can tell that the corners on the spoiler don't touch the body, so the mounting points are lower. Only thing you would have to do is drill holes to mount it... would be good to get the mounting hardware that the dealer sells, this way you avoid water leaks.
Test fit it first to see if its a go.
Old 07-29-2009, 09:41 AM   #7 (permalink)
YYYOOOOUUUUHHHHHHHOOOUUU!
Rookie_One's Avatar
View Rookie_One's Photo Gallery
It does fit, but need some adapting as the GT-S trunk lid is a little wider that the sedan lid
Rookie_One is offline   Reply With Quote
Old 07-29-2009, 10:03 PM   #8 (permalink)
'Rolla NiNJa
what kind of adapting? if the gts is wider wouldn't that mean the sedan would still have room on the sides??
as for the mounting... i was just gonna use some sort of sealer on the under side to prevent water...?
Old 07-29-2009, 10:59 PM   #9 (permalink)
Rookie_One's Avatar
well on mine theres some little plastic clips holding the wing on the side, as the wings is too large (dealer installed the wing)
will try to get some photos
Old 07-29-2009, 11:21 PM   #10 (permalink)
'Rolla NiNJa
i would appreciate a photo, cuz i'm having a bit of trouble visualizing what you're pointing out. srry
Old 07-30-2009, 01:52 AM   #11 (permalink)
KDM is in
REN69's Avatar
That's probably not a gts spoiler then... there's no clips holding mine on the corners that I can tell.
Here's an old pic of my car as a reference.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 07-30-2009, 02:06 AM   #12 (permalink)
'Rolla NiNJa
ok well here is what im talking about
http://i.ebayimg.com/21/!BUr4(c!!mk~$(KGrHgoH-DUEjlLlypo6BKOuN-pK4g~~_1.JPG
idk why is not hyper linking but just copy and paste address in address bar
Old 07-30-2009, 03:47 AM   #13 (permalink)
Rookie_One's Avatar
thats because the GT-S/SR5 Trunk Lid is wider than the Sedan Trunk lid
Old 07-30-2009, 08:42 AM   #14 (permalink)
Gameroom cash: $100900
View 4doorGTS's Photo Gallery
The gts spoiler has two studs for the center support and one on each end as well as the plastic stud that snaps into a plastic female piece on the trunk lid itself, I used back these plastic pieces when installing mine. Just take your time and make sure you measure it out properly fits just fine.
I still have the trunk lid with the spoiler too, if you were near by I could have sold it to ya.
4doorGTS is offline   Reply With Quote
