Hello Forum,
On my '91 Corolla sedan DX with only 34,000 original miles I plan to do a basic tune-up. I also plan to buy a timing gun. How do I adjust the timing? I am sure it is at 10 degrees but I want to know if there is a performance benefit to adjusting it higher & if so how high is too high? I don't want to affect its reliability because I plan to drive it out of state a few times. Reliability is my 1st priority which is why I am not going to swap out the engine just for more performance. I just want to get the most out of the 4AFE as is possible.
The only major mod I plan to do is to replace my 3 speed tranny with an overdrive one. Our transmissions are not computer controlled so all I have to do is wire a toggle switch for the OD to engage.
I also will replace the stock muffler with a DYNOMAX - 17731 series which supposedly breathes a lot better than OEM with no "fart can" sound.
I know that on the old carburated V8's adjusting the timing improved performance but I don't know much about the 4AFE.
P.S. I installed an instrument cluster with a tach off an LE corolla so I can monitor RPM's as I adjust the timing.
Let me know please, Thanks
