ignition cylinder - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-08-2009, 11:55 PM   #1 (permalink)
View auzzy101's Photo Gallery
ignition cylinder
i have been reading forums and i cant figure this out quite yet! i know theres a button to release the cylinder but i cant turn the key to acc. my key is broken off in the ignition and i can get it out. if i could either get it out or find out how to take it out i would really apprieciate the help!!......
auzzy101 is offline   Reply With Quote
Old 08-09-2009, 12:24 AM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
I'd say try using a small, good needle nose pliers. Or, put a small, small SMALL dab of crazy glue on the broken end of the key, put it in the ign cylinder so it butts up, let it dry for some time, see what happens.
Or you can replace the cylinder all together which would mean you'll get a new key, like it or not.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 08-09-2009, 02:48 PM   #3 (permalink)
1990 Corolla GTS 4A-GE
Createdtoburn's Avatar
View Createdtoburn's Photo Gallery
I had to replace my ignition cylinder a few weeks ago. Yeah I got a new key which sucks, one for ignition and one for doors/trunk now. But it wasn't that hard to do, only took like 20 mins, mostly just figuring out what to do. It's mostly visual of how it works, but it's pretty simple to install.
There's a little button thing underneath that pushes in only when the key is turned to a certain point... you just gotta line up the little metal tab thing on the end of the cylinder... it's hard to explain, but you'll see what I mean if you end up doing it.
Createdtoburn is offline   Reply With Quote
Old 11-13-2009, 05:21 PM   #4 (permalink)
View 3vz180's Photo Gallery
Canada 92 camry ignition
just replaced cylinder today..because i could not get the key to acc position i tried drilling the cylinder.no joy,what did work is drilling the release pin..i tryed hammering with a 1/8 punch no joy. use a long bit as it is hard to reach..it is also hard to pull out once drilled
3vz180 is offline   Reply With Quote
Old 11-14-2009, 09:26 PM   #5 (permalink)
View voganni's Photo Gallery
My local locksmith told me he can rebuild a Toyota ignition lock for about 20 bucks, and keep the same key you had. So, if you haven't destroyed it, just remove the whole works and take it to a locksmith.
voganni is offline   Reply With Quote
