autozone starter test wrong?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-09-2009, 03:03 AM   #1 (permalink)
View 4dRcOrOlLA's Photo Gallery
ok my 90 corolla hasnt been cranking for sometime now so i have people push it for me then i decided to get it tested to make sure that the starter was the problem being 6months old, and it passed so wen i put it back on it still woudnt crank!!!! wtf ive check everything and change everything from ground and power to changin ignition switch. can it b my flywheel or somthing take note that this is a reman starter
o yea it does crank but like once a blue moon(rarely)
and yes i do know i post a thread like this b4 but any help would b appreciated
4dRcOrOlLA is offline   Reply With Quote
Old 08-09-2009, 10:25 AM   #2 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
sounds to me like it's your battery cables.
'81 BMW R65
Old 08-09-2009, 12:10 PM   #3 (permalink)
where to i check it at because i checked all the possible cable points and does the test acutually test the solenoid during the bench??? thanks for your responce
Old 08-09-2009, 12:58 PM   #4 (permalink)
Gameroom cash: $134355
There's a couple things to check...
#1 is the battery cables... Toyota's are very specific, if the cable isn't tight a lot of the time it won't turn...
#2 the starter is bad... even though it passes a bench test, that doesn't mean the starter is good. A lot of the time the solenoid can get stuck and jostling it around (like when removing it) can get it to work for a few cranks. Also, keep in mind that when a parts store puts the starter on a tester, there's no load -- a starter may having a dying motor in it which has enough power to turn itself, but once installed it doesn't have enough 'guff' to turn the flywheel.
yes, a bench test checks the solenoid.... the solenoid is what takes the main power that's always connected to the starter then acts as a large relay when the 12V signal from the ignition is applied....
Old 08-09-2009, 07:10 PM   #5 (permalink)
wow thanks i think the starter is jus bad cuz me and my friend bypass the ignition and it still wouldnt crank or maybe it the brushes cuz i heard if its bad it wont crank but i would crank it at a good spot so maybe that spot is what cause my car to start every once a year lolz but thanks either way imma jus get another reman starter since its free and see thanks for the info i jus want to get it workin right so i can start my jdm image on a budget look lolz
Old 08-10-2009, 12:58 PM   #6 (permalink)
View AE92ROLLA91's Photo Gallery
My relay or something has fried on my starter. Honestly I'm not even sure it has a starter relay but I would assume it does. My car stopped starting the other day, I rebuilt the starter, same problem. I put it back in the car and crossed the wires on the starter and it worked so I just ran my own wire from the ign switch to the starter until I can find my problem.
Have you tested to see if your ign was actually putting power to the starter when you turn the key to the start position? I would look at that if you have checked the cables.
AE92ROLLA91 is offline   Reply With Quote
Old 08-10-2009, 01:02 PM   #7 (permalink)
View titleist's Photo Gallery
if it only cranks sometimes, i would check your starter contacts.
titleist is offline   Reply With Quote
Old 08-10-2009, 04:24 PM   #8 (permalink)
Yea I Have Check Power In The Ignition And It Was Good And Jus Today Ive Went Ot Advance Autoparts To Get A New Starter And They Couldnt Find My Name And They Put It On A Bench And It Faild!! So Now Im Pissed Off With No Starter
Old 08-10-2009, 05:50 PM   #9 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
Bring in the starter with your receipt and it won't matter if they can't find you in their system. They'll have to honor the warranty.
SuperRA is offline   Reply With Quote
Old 08-10-2009, 06:25 PM   #10 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
I drove around for a month with a hammer and metal bar in the trunk of my MR2. At least once a week it wouldn't start and I'd just have to rap the starter with the hammer and bar and it would work again. Worked great until I got around to replacing it.
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 08-10-2009, 10:16 PM   #11 (permalink)
My first one took that fine for a few months but eventually i beat a hole right through the starter.
Old 08-11-2009, 10:36 AM   #12 (permalink)
yea i dont have the receipt cant find it im so pissed i took this shit out like six times i can probably do it in my sleep and as for the hammer thing i did that for a month and dont work like that any more i guess it grew some ball and said fuck u asshole lolz
