Question about tires and rims - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-10-2009, 08:31 PM   #1 (permalink)
skateordie's Avatar
View skateordie's Photo Gallery
Canada Question about tires and rims
I was wondering if these tire specs will fit my rolla
Tires Specs - 175-65-14
Rims Specs - 14x6
Would it look too big or too small?if not, is it just the right size?
It's from an Aveo
skateordie is offline   Reply With Quote
Old 08-10-2009, 08:49 PM   #2 (permalink)
on full afterburner
Gameroom cash: $1346597
What's the bolt pattern and offset?
Old 08-10-2009, 09:07 PM   #3 (permalink)
j2b4osan's Avatar
View j2b4osan's Photo Gallery
I prefer the look of 15's. 14's should fit without a problem as long as lug pattern is 4x100 & the offset is correct. (15's in my sig)
88 sr5 100k Stock.
j2b4osan is offline   Reply With Quote
Old 08-10-2009, 11:18 PM   #4 (permalink)
skateordie's Avatar
It says Offset is 38 or 40..
So will it work?
Old 08-11-2009, 12:04 AM   #5 (permalink)
skateordie's Avatar
So will it work?
Old 08-11-2009, 08:03 AM   #6 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
they'll fit. They'll be a tad bit taller, but not much at all.
and the offset is good. it might be a little close in the rear, but with tires that skinny you'll be fine.
'81 BMW R65
Old 08-11-2009, 08:09 AM   #7 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
they should fit. they may rub just a bit in the rear though, but mine were a higher offset and possibly a wider wheel and it just barely touched. so nothing a small spacer shouldn't be able to fix.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
