Transmission Works - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-11-2009, 08:24 PM   #1 (permalink)
View cEtnA's Photo Gallery
Transmission Works
Hey guys i'm slowly but surely building up my car next is my trans planning to do a stage 1 clutch probably gonna leave a stock flywheel anything else i should change while i have the tranny off? i wanna pretty much make it brand new nice smexy clean smooth shiftage any imput would be nice thx
cEtnA is offline   Reply With Quote
Old 08-12-2009, 09:30 AM   #2 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
you can change your transmission fluid :-P.
other than that, I think you'll probably be good.
'81 BMW R65
Old 08-12-2009, 09:44 AM   #3 (permalink)
stancati's Avatar
View stancati's Photo Gallery
talk with 4DoorGTS, hes on the Club4AG Forum as well. He was telling me that you can use different shift linkage bushings and get a smoother feel on the stick, i honestly cant remember what exactly he was saying, but i would try and talk with him.
This was for the AE92 Coupe, not sure if it applies to all AE92's or not.
stancati is offline   Reply With Quote
Old 08-12-2009, 10:11 AM   #4 (permalink)
Blof-fan's Avatar
Gameroom cash: $294850
View Blof-fan's Photo Gallery
Is it a C52 tranny?
If so, I would replace the bearings to prevent the common '5th-gear-pop-out-problem' known with the C52
For an even smoother feel, you could even replace the synchromesh rings...but by then you're already looking at a total rebuilt
Driving : '92 Toyota T19 Carina E GTi
Repairing : '92 Toyota AE92 Corolla Hatchback GTSi
Restoring : '88 Toyota AE92 Corolla Coupé GT-S
My personal website: http://www.corollaae92gts.nl
Blof-fan is online now   Reply With Quote
Old 08-12-2009, 11:14 AM   #5 (permalink)
Rotary guy...
eage8's Avatar
he might have been talking about the metal bushings speed source sells
http://www.speed-source.net/
'81 BMW R65
Old 08-12-2009, 04:18 PM   #6 (permalink)
I'm probbaly gonna just do a rebuild I did change the trans fluid with Royal Purple though and felt a big differnce but the 5th gear does pop out when I play with the gas a little
Old 08-12-2009, 04:36 PM   #7 (permalink)
synchromesh ring? what's that and what does it do? also another question I had was since my car is pretty much 20 years old and it seems to have all the original parts..... (even what seems to be the very first airfilter) just bought it would changeing my engine mounts do anything for me? they seem pretty beat that's why
Old 08-12-2009, 08:09 PM   #8 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
I would at least replace the rear engine/gearbox mount. Just because it is so hard to replace with the engine in place. The others I would replace if it is in your budget.
Why are you going with a stage 1 clutch? Do you plan on racing? any power mods to the engine?
Why I ask, is that some performance clutches can be a bit grabby, causing the car to shudder when moving off, unless you have the RPMs high. Ok for racing, but not pleasant for driving around town.
If you do go with a performance clutch, make sure you get one with damper springs in the disk.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 08-12-2009, 08:54 PM   #9 (permalink)
I plan to boost down the line so I'm working backwards like upping the trans and engine internals is a stage one over kill for street? what do you recommend?
Old 08-12-2009, 09:03 PM   #10 (permalink)
Rotary guy...
eage8's Avatar
a spec stage 1? they're the only ones I know of that measure clutches in "stages"
no, that's fine for street.
anything with a sprung street disc will be fine.
I have an ACT in my FC that's good up until 443 ft lbs and it's fine to drive on the street albeit a little heavy... (it has a sprung street disc)
'81 BMW R65
Old 08-12-2009, 09:48 PM   #11 (permalink)
what's a syncromesh? sounds $$$
Old 08-12-2009, 09:51 PM   #12 (permalink)
Rotary guy...
eage8's Avatar
syncromesh = syncros
it's what brings your transmission output shaft up or down in speed to match the speed of the input shaft before engaging the next gear.
'81 BMW R65
Old 08-12-2009, 10:16 PM   #13 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
a synchro is the rings in front of the gears that match(.... or sychronize) the lay shaft (connected to the engine side of the tranny) and the output shaft( connected to the differential) since when changing gears, mainly in a downshift or a fast upshift, the shafts are spinning at greatly different speeds, if not the same speed when you go to put the car into gear it will grind.
These tend to get worn out over time, ask my third gear.....
if for some reason they do get worn to the point to where they grind they can be remidied by double clutching like I have to for 3rd. when you double clutch the lay shaft gets sped up so that when you put it into gear the shafts are closer in speed. Cars back in the day didn't have synchros, and large trucks still dont because of the amount of gears in trucks and I'm guessing they'd probably get shredded quickly under those types of loads.
Sadly to get at these you'd have to crack into the transmission which either takes lots of special tools and knowledge, or lots of labor time for someone who does have those. also rebuild kits with synchros can get pricey, I think autozone wanted about $800 for a rebuild kit for my S53 transmission.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 08-13-2009, 09:57 AM   #14 (permalink)
Blof-fan's Avatar
And RobMilkshakes wins the refrigerator!
The synchro's make shifting from one gear to another, smoother without grinding noises
I rebuilt my gearbox myself and if you do a full rebuilt, it can get expensive.
But on the other hand. If you plan to drive or tune the car...you'll have a gearbox that's as good as new and that can handle a lot of abuse for years to come!
And while the tranny is open...why not put in an LSD while you're at it? Does a lot of good for the handling!
But like said before: It's expensive and it should be done by a specialist. It's not a DIY for most people
Old 08-13-2009, 11:55 AM   #15 (permalink)
Donald's Avatar
Yeah! If you are planning on boost, a stage 1 clutch will be a good idea. Just make sure you get a disk with damper springs.
