89 SR5s don't have TPS's so either your looking at the wrong year's error codes or it means the throttle switch, which is on the carburetor somewhere... I forget which one it is though. it's one of the things with a wire(s) going to it :-P
'81 BMW R65 For Sale: GT-S strut bar + Front GT-S koni yellows
ok, so I looked them up and it turns out 41 is the throttle switch.
31 is a problem with your vacuum switching valves' signal. these are the 2 valves that sit in the top middle of your firewall.
the throttle switch is tricky to find. if you look at the last picture you posted, it's right bellow where the fuel line meets the carb (with a banjo bolt). it should just be a little plunger thing with a wire coming out of it.
