look at your brake pedal arm just below the hinge.
There will be a tab that operates the brake light switch.
On that tab should be a rubber pad.
If this pad is missing, that will probably be the problem.
If the pad is there, and it has the switch pressed all the way in, then the switch is bad.
If the switch is not pressed all the way in, then it needs to be adjusted.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
