well you'll have a little trouble fitting an ae111 inside of an ae92.... :P
(the ae111 is the chassis code for the whole car, A- engine series, E-corolla chassis, 111- generation)
there are tons of threas explaining how other A series engine will work, here is a general guide to get you started:
Common Engine Swap Guide
I know right now eage8 is working on swapping a 20v silvertop into his car which should be very close to the blacktop that you are talking about(or at least think you are talking about?).
but short answer yes it will fit, the mounts are in the same spot but you'll possibly have to use other brackets/mounts themselves, I know this is addressed in eage's thread. About the transmission though I honestly cant remember what tranmission series it is so I dont know whether the axles are the same or not but I do know theres an issue retrofitting the shifter to accept a 6 speed. and wiring will be very different but all these answers can be found in a lot of threads
