Is there anyone who knows, will my 4AFE Celica transmission c50 or c52 will fit 4AGE Blacktop???
I asked everywhere, even on the celica subforum on TN...
I think it will, being "A" engine blocks, they should all be interchangeable.
I am not sure about this either, but I think it will require that you use the clutch for the C50/52.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Thanks for answers, so the tranny will fit, and what about flywheel? The 20v one has 8 crank mounting bolts, and the 4afe have 6...
And the 20v fly is 212mm in diameter, is this going to be a problem?
So the better deal is to go for c56 tranny?
Will my 4afe axles be compatible with 4age gearbox?
it depends, if you get a blacktop with a c56 the clutch condition is a mystery. you might still have to change it. the c56 does have shorter gear ratios though.
yeah, the 4afe axles are compatible. I just put axles for my old c50 into my new c56 yesterday.
'81 BMW R65 For Sale: GT-S strut bar + Front GT-S koni yellows
Excellent, thanks...
And im just curious, will my axles and linkages work on a c160 transmission?
The linkage will work, but you will probably need to modify the shifter mount to get more lever throw, by a bit of grinding at a few key locations.
There is a thread on here for the C160 installation into an AE92, it should be the same for your Celica I think. It is in the Read Me section at the top of the front page of the AE92 forum.
@donald - thank u very much...
But there is still question about axles, what if c160 come with lsd, and what if not?
From what I have read, the LSD gearboxes use a different axle, and they are not interchangeable.
So if you get one with LSD make sure you get at least the stub of the axle that goes into the gearbox (I think they call that the tulip).
The rest of the standard axle fits that, I think. (not sure)
