4AF questions. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2009, 02:27 AM   #1 (permalink)
View darth-grantius's Photo Gallery
4AF questions.
Does the 4AF have worse economy then a FE or GE?
My Corolla has one and i get fairly bad economy. I used to run it on 91 octane but then switched to 95 because the manual stated it, which gave it a little better economy. But the cars been run on 91 for the last 19 years - would that make the engine bad?
Also - does the 4AF have a rev limiter?
darth-grantius is offline   Reply With Quote
Old 09-03-2009, 02:36 AM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
AE92
I don't think they have that much difference in mpg as long as the 4AF is well tuned. As for gas, I used to run premium but I do regular now. Just adjust the timing and all...
And I don't think the 4AF has a rev limiter... I have 240000+ miles, I wouldn't wanna try.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 09-03-2009, 02:38 AM   #3 (permalink)
Ohk would tuning it make it better?
My cars done 151k kms.
Old 09-03-2009, 03:00 AM   #4 (permalink)
SCT
iAzn
SCT's Avatar
Carbs go out of tune over time. Then you have to do the fine adjustments... ie idle, fuel trim, etc. EFI is all electronic so no re-tuning is required (not as much as carbs). If everything is tuned close to perfect, mpg should be very good. Right now, I get between 24mpg up to 37mpg! I think I reached 37mpg by letting my car coast down at idle when I going down slopes on highways and stuff (i have a stick).
If the car lacks power, runs rich, runs lean, spits, choke, runs rough, idles rough... Carbs likely out of tune.
Old 09-03-2009, 03:05 AM   #5 (permalink)
Far out man. I get an average of 8-10kml.
Old 09-03-2009, 05:58 AM   #6 (permalink)
j2b4osan's Avatar
View j2b4osan's Photo Gallery
I rebuilt my carb last year and it gets far bettr gas mileage now. The only pia was adjusting the float because if you don't get it right you gotta take the whole thing apart again.
88 sr5 100k Stock.
j2b4osan is offline   Reply With Quote
Old 09-03-2009, 09:43 AM   #7 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
when I still had my stock sized wheels and tires I could get 40 mpg out of my 4AF driving really carefully. but as soon as I put the 15s with 205/50/15s on it that went out the window. I was getting about 24 mpg average when my engine died at 225k miles
'81 BMW R65
Old 09-03-2009, 02:10 PM   #8 (permalink)
ok i might do this sometime soon. thanks guys
Old 09-03-2009, 03:27 PM   #9 (permalink)
Rotary guy...
eage8's Avatar
or you could just get a weber 32/36
it's supposed to get better gas mileage than the stock carb.
'81 BMW R65
Old 09-03-2009, 05:40 PM   #10 (permalink)
is it hard to put a new carb on?
Old 09-03-2009, 07:10 PM   #11 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
it's easy to put a new carb on. Unbolt everything attached to it and then reverse for the new one.
If the car is tuned properly the gas milage should be about the same, as long as you don't push it since carbs just start to dumb fuel in.
Only time I have run premium in mine was when the carb needed to be cleaned the extra octane made it run better.
No rev limiter on my 4af, hit 8000 with it before... DO NOT RECOMMEND since the valve float at 7000 (or did when new), I did it accidentally when I first started driving it and was messing around.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
