Question about rear struts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-04-2009, 07:25 PM   #1 (permalink)
View JasonK94Z's Photo Gallery
I just ordered rear struts for my car off ebay for a great deal. The car has 248k miles and they are shot.
Will changing out the rear struts affect anything with the alignment?
Does anyone have a diagram of the strut assembly?
Is the upper mount portion accesable from the trunk or do I need to remove the back seat?
Can I get away without having to buy new strut mounts or anything else?
I just want to stop the back of this car from bouncing up and down all the time LOL. I'd rather not invest any more money into this car than i have to. The car was purchased for $500 just to take me to work with good mpg.
Thanks everyone for the help.
JasonK94Z is offline   Reply With Quote
Old 09-04-2009, 08:35 PM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
remove the seat back to get at the strut tops. its easy so its no biggie.
The strut wont change your alignment
and here's a diagram:
http://www.toyodiy.com/parts/p_U_199...HDKA_4804.html
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 09-04-2009, 08:39 PM   #3 (permalink)
Appreciate the help! Thanks for the replies in all my posts.
Old 09-04-2009, 09:37 PM   #4 (permalink)
j2b4osan's Avatar
View j2b4osan's Photo Gallery
mounts would be cheap and a good investment because if the fail it may damage the car. its easy no alignment necessary.
88 sr5 100k Stock.
j2b4osan is offline   Reply With Quote
Old 09-05-2009, 07:46 AM   #5 (permalink)
Aargguu! Mounts are $51 a piece. We'll see what the old ones look like next weekend.
Old 09-05-2009, 01:48 PM   #6 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Ha-ha-haaa.
You are going to find out sooner or later that you have fallen in love with this car, and start wanting to invest in it.
Remember that I said this when you start thinking about a blacktop or a GZE.
Replacing the rear struts might not affect the alignment, but it could possibly affect the camber very slightly. So, if you dont have the alignment checked, you should keep an eye on your tires to make sure that they are wearing evenly.
The strut mounts seem to hold up very well. I have never had to replace any on any of my Toyotas.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 09-07-2009, 12:03 AM   #7 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
if he has the fold down rear seats he doesn't have to removed them. On mine there is a small panel you can remove and if you are careful don't have to remove the rear deck either.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 09-07-2009, 05:29 PM   #8 (permalink)
It doesn't have fold down seats. The bottom cushions come out though.
Old 09-11-2009, 05:39 AM   #9 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
on the 89 Corolla SR5 there is only about 3 inches between the nuts and the read window for the shock towers ont he rear deck...
but the back are still easier than doing the front struts..
I hope you got a warranty with the ones off eBay..
The Gabriels I got from Auto Zone a few years back took at least 5 years to soften up... they were very hard for a long time,, very stiff..
the originals were 225,000 miles on them and had no dampening at all..
now the car has 350,000 miles..
new struts were about $160 for 4 struts at AutoZone around 1994..
lifetime warranty..
they shop wanted $800 labor for 4 struts...
1989 Toyota Corolla SR5, Carb.
1993 Camry LE
retiredat44 is offline   Reply With Quote
Old 09-11-2009, 07:44 AM   #10 (permalink)
Vroom?
freakinbox's Avatar
on the sr5 I'd say the fronts are easier... no sway bar links to mess with on the front... since mine are siezed in the rear and cheapest I have found is a little over $100 per sway bar link...
Old 09-11-2009, 08:03 AM   #11 (permalink)
Not sure if the Prizm LSi has a sway bar in the rear or not. I did see how much the links are the other day and about crapped myself! What the heck is the reason for such an expensive sway bar end link? On my Camaro Z28 they are $13/pair LOL.
1992 Geo Prizm Red
248k miles on it so far 9/9/09 and still in great shape!
4AFE engine, A131L 3-speed auto trans
1994 Camaro Z28 - The modified gas guzzling beast
Old 09-11-2009, 10:46 AM   #12 (permalink)
Vroom?
freakinbox's Avatar
because the ae92 parts aren't nearly as common as they used to be. The cap and wire set for my car went from $60 for the decent cheap set and they now cost $110, $120 from the dealer.....
I am not sure on the sedan, if it has a rear sway bar or not. Some have said they don't have them and some said they do. But typically on most cars they are cheap because they usually seize up. and are just a small part.
Old 09-11-2009, 10:50 PM   #13 (permalink)
Gameroom cash: $134355
the coupes are a pain in the ass..... you have to remove the seat lower cushion, back custions.... then you have to remove the inside C pillar trim... which requires unbolting the seatbelt, removing the lower trim first, then the c pillar trim, removing the 3rd brake light, removing the speakers.... then if you're lucky, you won't break the rear dash-board when it comes out.....
I prefer the cars where you can actually access the rear strut tops.....
Old 09-12-2009, 06:42 AM   #14 (permalink)
Slacker Extrordinaire.
View ae924d's Photo Gallery
i mean if you want to have a car where you can change them easily you'd have to defect to honda...you dont have to take out shit, just pop open your trunk and boom.
1994 Acura Integra RS (DC4)
1985 Toyota MR2 MKI-A
ae924d is offline   Reply With Quote
Old 09-14-2009, 07:10 PM   #15 (permalink)
RED91SR5's Avatar
View RED91SR5's Photo Gallery
I recently did this, what a pain in the ass the coupe struts are!
RED91SR5 is offline   Reply With Quote
