4AFE Common Oil Leaks? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2009, 09:14 AM   #1 (permalink)
View JasonK94Z's Photo Gallery
Question 4AFE Common Oil Leaks?
I have a pretty good oil leak that needs to be fixed. Seems like it is coming from around the crank pulley area maybe.
What are the common oil leak points on this engine?
I will be replacing the timing belt and water pump soon, and it would make sense to replace the seals at this time. Is the oil pan able to be taken off without lifting the engine? The pan is leaking a bit, but this other one is the worse one whatever it is.
JasonK94Z is offline   Reply With Quote
Old 09-07-2009, 10:13 AM   #2 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
Most common leaks:
distributor shaft o-ring
valve cover gasket
rear main seal
People often falsely diagnose a leaking oil pan when it's really something higher up on the block.
My best advice for leaks is to hose it off with some degreaser and then put some UV dye in the oil, run the car for a few minutes and then look at it with a blacklight.
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 09-07-2009, 05:32 PM   #3 (permalink)
Its definitely coming from the pulley area. The valve cover gasket is brand new. So it's either the seal behind the crank pulley, or the cam seals.
Old 09-07-2009, 11:52 PM   #4 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
Yea when you change out the timing belt, since you have to remove the crank pulley and crank timing sprocket, it's best to just replace that crank seal... Takes no effort and saves you if it actually goes bad down the road IF it appears to be good now.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 09-09-2009, 01:17 AM   #5 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
The oil pans tend to be a common leak, since they only used gasket maker for them. Usually what I do is clean up everywhere there is oil and drive it for a couple days, avoiding alot of dirt and such and then check to see where it's comming from.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 09-09-2009, 01:59 AM   #6 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Do you even drive that car?
Old 09-09-2009, 02:55 AM   #7 (permalink)
Vroom?
freakinbox's Avatar
Not at the moment, I am broke and people thought it would be cool to break into it and bend the arm and snap the mechanism for the turn signals :@, messed the windshield up a little more, and stole the faceplate and remote for the radio leaving the radio (woot for properly installing things, you need tools to get it out ). That and it needs a few things to pass the e-test so I can get my stickers updated.
But I still own it and will as long as I possibly can lol
Old 09-09-2009, 12:31 PM   #8 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Oil pump seal.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
