Finally!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-08-2009, 11:57 PM   #1 (permalink)
View fremontguy01's Photo Gallery
AE92 Finally!!!
After a week of searching through wrecking/junk yards i finally found a ae92 with a sunroof that isnt rusted beyond repair. Also a plus, after removing the rubber seal on the sunroof i inspected it,... perfect. No cracks, nothing. Does not look weathered at all, strange. Got the rails and everything, on my way out noticed another one in the prep yard. Spoke with manager, he told me it will be in the yard by next week. Its been a good day,.... By the way anyone know of a way to remove deep rust efficiently and thoroughly besides electrolysis?
Torn
fremontguy01 is offline   Reply With Quote
Old 09-10-2009, 12:50 AM   #2 (permalink)
Wonderbread
4agetercel's Avatar
Gameroom cash: $160040
View 4agetercel's Photo Gallery
cut&weld, not always an option though
4agetercel is offline   Reply With Quote
Old 09-10-2009, 11:32 AM   #3 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
Hey, were either of them a GTS? I need a few small parts. Which yard was it?
As for the rust, if it isn't too thick, there is a chemical you can get from eastwood that dissolves rust. POR15 also has one called metal ready.
SuperRA is offline   Reply With Quote
Old 09-10-2009, 12:10 PM   #4 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
Hey fremontguy, which yard was it? I have a need for a sunroof myself. Matter of fact, if you've still got your rusty old one, I might be interested in that too.
Regarding the rust removal... electrolysis really is the best method but failing that, you can grind and wire brush as much rust as possible off and then coat it with something like POR15, Ospho, or a similar rust fighter. Then paint over that coating as most of them aren't UV-compatible in the long term.
I've got an electrolysis bath set up in my backyard right now if you'd like to drop off the panel sometime I'd be happy to clean it for you. I'm in Santa Cruz.
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 09-10-2009, 12:20 PM   #5 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Muriatic acid, then wash it off with water then apply your protective coat..
There is also a kit for cleaning rust from motorcycle fuel tanks and then coating it with an enamel like substance. It it is a three part kit with an acid, a drying agent and the enamel coat. It is called Kreem Kit, and I believe you can get it online or from any motorcycle shop.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 09-10-2009, 02:12 PM   #6 (permalink)
RED91SR5's Avatar
View RED91SR5's Photo Gallery
A good media blasting tends to do the trick as well. Then coat with whatever protective coat you like.
RED91SR5 is offline   Reply With Quote
Old 09-10-2009, 04:50 PM   #7 (permalink)
This works well if the rust hasn't spread in between the layers. Otherwise you can separate the layers, blast, and then re-weld afterward. That's what I did, but it's a bit of work.
Old 09-11-2009, 09:37 AM   #8 (permalink)
Thanks guys! The yard i found it in was pick your part in hayward off of winton. The car i got the sunroof off of was a sr5 but i couldnt tell if the one in the back was a gts or sr5, i was only able to see a portion of the front end. Ghostyman, i have to wait until monday/tuesday when i get my car back to see if i really need that sunroof or not. I know the rails and maybe the motor i need, but not too sure about the roof panel. If not its all yours, and i might have to take you up on that offer sometime.
Old 09-13-2009, 04:29 PM   #9 (permalink)
For those in Northern California I found two gts's in Milpitas at Pick Your Part.
Old 09-14-2009, 12:07 AM   #10 (permalink)
Ooh oh OOO
There goes my saturday. I hope they're still there by then.
Old 09-14-2009, 02:44 PM   #11 (permalink)
Gameroom cash: $100900
View 4doorGTS's Photo Gallery
Someone get me some clean power steering lines so i can throw the engine back in the car.
4doorGTS is offline   Reply With Quote
Old 09-19-2009, 06:32 PM   #12 (permalink)
Ghosty, the pick your part in Milpitas has as of now a GTS and an SR5. Both have a sunroof, both red, both have some rust. Altough they have rust, it's less than the one I worked with and restored.
Old 09-19-2009, 06:53 PM   #13 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
^^^ You're a hero.
Old 09-19-2009, 08:59 PM   #14 (permalink)
I just about died out there. I hope I'm not sunburned. =(
At least i got me a C52 or at least I hope it's a C52.
The GTS still had the strut housings if someone needs them. It's 4AGE is already pulled and on the ground in front of it too. It's missing the valve covers and some other small parts. The strut brace is sitting inside the car.
Old 09-19-2009, 10:23 PM   #15 (permalink)
Are the power steering lines still intact? If so can someone grab them for me?
