Originally Posted by dreamer97
Fluid level has been monitored ever since the pump has been changed and surprisingly remains full. is it possible that the pressure hose that is connected to the rack is clogged or has a hole in it. I was thinking that it was air in the system initially.
did you bleed the rack from air when you put the pump in?
my power steering had a huge problem like yours at about 225,000 miles.. It would go on and off when near idle and when cold would not work at all..
I bought a pump rebuild kit for $20 (or $13,00 maybe) and rebuilt the pump with the new seals. I bled the system (as per the manual..) and it took a while and some driving, all has been well for many years now.. but the rack could use rpelacement as the steering wheel is not as not perfect center and has a small bit of slop with 350,000 miles.. not bad,, but nothing near as nice when new..
