Need Help With Rod Knock - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-12-2009, 11:55 PM   #1 (permalink)
View sonoronos's Photo Gallery
Car stats:
1992 Toyota Corolla
4A-FE engine, 5MT
187,000 miles on odometer.
Situation:
1. Slight rod knock detected on acceleration/load only. No rod knock at idle.
2. Drove on slight rod knock for 3-4 miles to go home.
3. Pulled oil pan and hand-checked each rod for play.
4. Slight play found on cylinder 1 bearing only.
5. Removed cylinder 1 rod end cap and bearings.
6. Cylinder 1 Bearings show wear as in attached picture.
7. Cylinder 1 crankshaft journal shows no wear.
What is the correct course of action in this situation?
1. Replacement/rebuild of entire engine?
OR
2. Replacement of rod bearings to original clearance spec?
What is your assessment based on the photo of the rod bearings attached?
Should I measure concentricity of the crankshaft journal to verify that it is not out-of-round?
Any help appreciated.
http://yfrog.com/4rrodbearingscylinder1j
sonoronos is offline   Reply With Quote
Old 09-13-2009, 10:44 PM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
Those bearings look fine...
Usually, when accelerating uphill and/or with load, when you hear knocking sounds it's because it's the wrong grade of gas and/or retarded timing. Or, if it has one, a faulty knock sensor, which I doubt AE92's have any. So, adjust your timing OR try running a different grade of gas. I use regular.
If bearings were going, it would not take long AT ALL for the motor to lock up or sound VERY clunky whenever the engine is running.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 09-14-2009, 12:04 AM   #3 (permalink)
Hi! It is definitely rod knock.
I could wiggle the rod while attached to the crank by hand, leading to a slight "click-clack" noise. The rod was not visibly moving, but I could feel it wiggle, and there was noise. This noise leads to the "rod knock" noise when under load.
The rods on cylinders 2-4 did not make a sound, nor did they wiggle.
I guess my question is, can I simply replace the rod bearings, or is it necessary to rebuild/replace the entire engine?
Old 09-14-2009, 10:43 PM   #4 (permalink)
wondermelon's Avatar
View wondermelon's Photo Gallery
the bearing looks like it is in fairly normal shape... if you were hearing audible knocking sounds i would expect to see bits missing from the bearing and more of a rough appearance. if the journal is still polished i think that should rule out rod knock, but someone more experienced should correct/confirm on that. if you decide to just put it back together i think it would be a good idea to use a new bearing.
perhaps it is the "small end" bushing that is the problem?
check your starting injector to make sure that it is not leaking. mine was and contributed to a rod bearing failure.
wondermelon is offline   Reply With Quote
Old 09-15-2009, 12:13 AM   #5 (permalink)
Thanks for the reply folks.
Good point on the small end - I haven't removed the head, so I have not had a chance to check the piston pin/rod interface yet.
I am 100% certain the rod bearing is the issue. It failed the simple test of me jiggling the rod with my fingers. Stock bearing clearances should not allow any jiggling at all.
The #1 Cylinder rod jiggled with a "click-clack" when motivated by hand. If I can do that with my hand, imagine what it would sound like with 150+ psi of combustion pressure against it.
That's the rod knock acid test. It's very simple - no guessing. Just remove the oil pan and jiggle the rod with your hand.
No starting injector on my 1992 4AFE - just 4 standard injectors. All injectors running perfectly.
Old 09-15-2009, 08:43 AM   #6 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
you need a micrometer, but most likely you really should go with the next size in bearing and have the rod sized for the next size bearing.. that is where the rod is machined so the next size bearing will fit.
I myself would take off each rod end cap and replace each bearing. That is each remaining bearings would be the standard size. They are inexpensive. If the micrometer shows them being out of tolerance than all would go to the next size bearing.
1989 Toyota Corolla SR5, Carb.
1993 Camry LE
retiredat44 is offline   Reply With Quote
Old 09-15-2009, 12:15 PM   #7 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
I can't see the photos (I'm at work), but I would say just replace all the big end bearings with the correct size bearings, while you have the oil pan off.
For about $35, that is real cheap preventitive manitenance.
It will bring your oil pressure back up closer to where it should be, which will be good all round.
For the bearing size, there should be a set of numbers stamped into the lower surface of the block, near the transmission on either side. I don't remember which is for which set of bearings, but if they are all 2's on both side then you have standard beariings.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 09-15-2009, 02:43 PM   #8 (permalink)
Gameroom cash: $134355
there's no copper showing.... was the rod movement side to side or forward/backward (if you could wiggle the rod a tiny bit in the same direction the crank faces, that's somewhat normal.... )
Old 09-15-2009, 04:02 PM   #9 (permalink)
Donald's Avatar
Ok now I can see them. Those bearings don't look bad, but I would replace them just the same.
You might be hearing piston slap, and not a rod knock. If you replace the bearings and the noise is still there, your piston to cylinder gap would be my next suspect.
Old 09-16-2009, 09:18 PM   #10 (permalink)
or a possible spit shim or really badly worn shim(s)
Old 09-17-2009, 03:14 PM   #11 (permalink)
View fredricktflail's Photo Gallery
Thats what the bearings on my 7a with a rod knock looked like mine were a little worse except on rod throw 4 where it was flattened and mealted to the crankshaft I'd replace all of them with the same size unless the crank or the rod are chewed up or look distorted, also if your rod bearings are bad theres a good chance your mains are fried too. Also plastigage the bearings when you chance them to check oil clearance.
fredricktflail is offline   Reply With Quote
Old 10-04-2009, 11:04 PM   #12 (permalink)
Thanks....I went ahead with the swap.
Thanks for the posts guys. Based on what you folks stated, I decided to swap the engine.
Here's a summary of the process I followed:
In considering my options, I carefully looked the rest of the engine over. I removed the valve cover and examined the cams. I noticed that the cams were actually worn - most likely this was due to a low oil condition. The reason for the low oil condition was increasing oil leaks due to loose oil pan bolts. If you have a 4AFE please check your oil pan bolts and make sure that they are tight!! Also, make sure your gasket is good. If there is no gasket, then use a silicone high-temp RTV.
Obviously, overhauling the existing engine would mean replacement of a large number of parts, including the camshafts. Therefore, I explored the option of buying a used engine.
I found a used 4AFE from a 1992 Corolla with a claimed 104,000 miles on it. After purchasing the engine, I performed a basic teardown, removing the valve cover and the oil pan. Visual inspection showed the cams looked like new and no sludge in the oil. Rod bearings on all 4 cylinders were quiet.
A leakdown test was performed @ 100psi input pressure through a 0.060" orifice. Initial results showed less than 8% loss across cylinders 1-3. Cylinder 4 initially showed 35% loss through the exhaust valve. I used a screwdriver and tapped the valve shim a few times with a screwdriver and a rubber mallet to dislodge any carbon. Loss dropped to less than 10% after a few taps. All was well.
Total time for the swap took about 40-44 hours, since I had to do it alone and this was the first time I had ever done an engine swap. The paper reference I used was the HAYNES manual, which had torque specs for the critical bolts. However, I must say that it is a pathetically incomplete resource. It had enough to get the job done, but if you have the ability to get a more complete reference, by all means, please do.
I also replaced the following in the process:
* Intake Manifold Gasket
* Exhaust Manifold Gasket
* Distributor O-ring
* Camshaft Front Seal
* Rear Main Seal
* Rear Main Gasket
* Clutch / Clutch Throwout Bearing
* Front Main Seal
* Timing Belt
* Timing Belt Tensioner
* Water pump
* Transmision Fluid (Mobil 1 MTF)
Here are some things I learned from the swap:
1. I needed to use two impact wrenches. One that is small and makes 250-300 ft-lbs of torque but is light and can get into small spaces. The other is a heavy 1400 ft-lbs monster with a 3/4" drive. I had to use this to remove the crankshaft bolt, the 3 lower a-arm bolts from each of the front wheels (which I had to remove in order to remove the driveshafts). Just a few seconds with the monster works where 30 seconds of constant hammering with the smaller torque wrench @ 120 psi fails.
2. The front crossmember is a b**** to remove.
The reason it is difficult to remove is that Toyota designed the rear engine mount bolts to fix the crossmember in place. The problem is that you cannot easily lift the engine high enough to have the rear engine mount subframe bolts clear the crossmember. It took me literally 4 hours to figure this step out. The correct way to do this is to remove the driveshafts first, which then allows you to remove the rear engine mount cross-bolt, then lift up the engine and remove the engine mount.
I also used my plasma cutter to modify the crossmember so that it no longer is clamped down by the rear engine mount. No structural problems doing this. The benefit is that I can remove the front crossmember without having to remove the rear engine mount, which means that I can drop the oil pan in the future without needing an engine hoist!
3. Removing the intake is a pain in the butt.
The secret to this step is to remove the driveshafts first, then the starter motor. Then disconnect the intake manifold reinforcement bar and the vacuum manifold, then any vacuum lines. The vacuum lines will prevent you from moving the intake manifold away from the firewall.
4. Timing is easy to preserve, just make sure that you always leave the engine at TDC and mark the TDC points for three critical places: Distributor, Camshaft Gear, Crankshaft Sprocket. If you find it difficult to remove the Camshaft Gear bolt, you can use a small impact hammer. Because of the way that the impact hammer works, it will not rotate the camshafts when you loosen the bolt.
5. Putting it all back together takes about 3x less time than taking it apart.
6. Easy way to remove the engine from the transmission with one person:
Remove the rear and front engine mounts. Remove the left engine mount bolt. Keep the right transmission mount attached to the car.Lift the engine out of the engine bay with a chain attached to the lift-hook located next to cylinder #1 (left side of the engine). Lift it straight up until the entire assembly is cocked at about 30-35 degrees. Place a jackstand, hydraulic jack, or other stable object underneath the transmission. Undo the four transmission bolts and gently lift out the engine. The engine should remain at about 30-35 degrees and slide easily out of the transmission. Keep the transmission where it is. When it comes time to replace the engine, just lift the engine to the same point and re-connect the clutch to the input shaft, gently sliding together the engine and the transmission.
7. I know I mentioned it a few times, but remove the driveshafts first. It will make your life a lot easier. You will need a 30mm deep socket driver to remove the driveshaft nuts. Then remove the two nuts and one bolt holding the bottom a-arm to the knuckle (do not mess with the balljoint.) The easiest way to remove the driveshaft from the knuckle is with an air-chisel using a single-point tip. Just press into the little hole in the tip of the driveshaft.
Once you are finished with the swap, fill the engine with oil, disconnect the plug wires from the plugs, and crank the engine continously until the low-oil light turns off. Then a few more times to be sure. This took me about 60 seconds of cranking the engine. Replace the plug wires, start the engine, and check idle. Everything worked the first time for me.
I plan on changing the oil and filter within the next 100 miles just to make sure that no dirt/gunk ended up in the bottom end during the swap
Here are some pictures from the engine swap:
By sonoronos at 2009-10-04
Old 03-06-2010, 12:36 PM   #13 (permalink)
View scotto-'s Photo Gallery
Nice Job, very informative with lots of pics. Thanks!
scotto- is offline   Reply With Quote
