Dead head-swapping engine for upgrade! Need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-16-2009, 04:00 PM   #1 (permalink)
View Surferjer's Photo Gallery
I have a 4AGE with a dead head (went with head gasket) and since I'm swapping heads and or motors anyway, it's time to upgrade! My car is a 87 FX16 with a fuel injected blue top.
If i put in a red top head (small port), what else would I have to do to make it all work?
If i swapped to a silver or blacktop, what issues will I face?
Which of the three will "harness right up"?
What peripherals will need to be replaced? Alternator, distributor, Starter, fuel rail, etc? I think my transaxle will be fine with any of them (according to the sticky), but i could be wrong.
Thanks for any and all guidance. I am looking for fast reliability on the track. The FX16 has been a great car and deserves more than 112 HP. I'd even consider another bluetop head with a cam upgrade, but it seems to be a better idea to do more for less with a motor swap. If a redtop head is easy and quick, that might do it, too.
I read the stickies, and I did a search. Please help!!!
Surferjer is offline   Reply With Quote
Old 09-17-2009, 09:56 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Swapping to 20V your only issue would be wiring, everything else would be straight forward.
Smallport head will most likely require the smallport ECU and electronics, I think a redtop bigport head would be a quicker swap.
Old 09-18-2009, 08:43 AM   #3 (permalink)
A bogport wouldn't provide any noticable performance improvement, right? I'm looking to step my HP up. So if I go smallport I'll also need the ECU? bummer, but doable...
Old 09-19-2009, 07:34 AM   #4 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
the easiest mod will be to reinstall a big port head with small port pistons.
That will bump up your compression and give you better torque and HP, and won't require any other mods(wiring, ECU, etc).
+ cams will be good too.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
