the reason I ask is that sometimes in the morning if I hit the gas hard from a stop the car will die or do nothing(almost stall) for a min before I back off the gas. I figure Im flooding it because the car hasnt fully warmed up yet. is there an adjustment I can make from the outside of the carb to adjust the a/f mixture? is it just driver error or a bad mixture?
Theres an mixture screw un the back. But what you're saying is pretty much normal for carbs, your accelerator pump should compensate for it, but maybe its not working properly. Its usually a lean spot and from your description it is.
