Bad Clutch Hydraulics test Slave vs Master? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2009, 11:23 PM   #1 (permalink)
View BugDiddy's Photo Gallery
Hey guys I have a hydraulic clutch issue in my 89 All-Trac. There is no fluid loss, just loss of pedal pressure, so I know its not an external leak.
This leads to the master cylinder or the slave cylinder but I dont want to buy both if only 1 is bad. Is there a way to test which part has gone bad?
BugDiddy is offline   Reply With Quote
Old 09-26-2009, 02:29 AM   #2 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
Try bleeding it? Even try flushing the fluid.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 09-26-2009, 12:57 PM   #3 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
I don't believe you can have an internal leak in the slave cylinder. If it has gone bad, it would leak externally. The master cylinder however might be able to leak back into the reservoir or worse yet leak into the passenger compartment. Did you check on the rug near the pedal to see if it is leaking there?
SuperRA is offline   Reply With Quote
Old 09-27-2009, 11:34 PM   #4 (permalink)
I guess that answers my question... there is zero fluid loss, just pedal pressure problems. so I guess the master cylinder is the bad part.
also i have already bled the system 4 or 5 times so I'm pretty sure the problem lies in a 20 year old seal.
