Speedometer Problems. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-28-2009, 07:59 AM   #1 (permalink)
BORICUA
jungobaez's Avatar
View jungobaez's Photo Gallery
Gen6 Speedometer Problems.
My speedometer wasn't working, so I decided to change the whole cluster from a DX to a LE. Everything else works except for the speedometer. Any suggestions?
Edwin "Jungo" Baez
jungobaez is offline   Reply With Quote
Old 09-28-2009, 09:26 AM   #2 (permalink)
patcal's Avatar
View patcal's Photo Gallery
Is the cable pluged into the back of the speedometer head? Is the end connected to the transaxle? When I did my LE cluster swap the cable was the hardest part to get seated because of my fat hands.
Pat Callaghan
90 Corolla DX
Portland, OR.
patcal is offline   Reply With Quote
Old 09-28-2009, 10:07 AM   #3 (permalink)
BORICUA
jungobaez's Avatar
Yeah, it's connected on the cluster, but I haven't check the transaxel though.
Edwin "Jungo" Baez
Old 09-28-2009, 10:23 AM   #4 (permalink)
RED91SR5's Avatar
View RED91SR5's Photo Gallery
Sorry, not to hijack the thread but is the LE cluster swap a direct swap or is there wiring to change? I picked one up and haven't had the chance to install it into my sedan yet.
Oh, try and spin the speedo on the back of the LE cluster by hand to see if the needle works, maybe something in the cluster came off.
RED91SR5 is offline   Reply With Quote
Old 09-28-2009, 11:29 AM   #5 (permalink)
BORICUA
jungobaez's Avatar
its a direct swap. Im going to have to disassemble everything again to check it out.
Edwin "Jungo" Baez
Old 09-28-2009, 10:06 PM   #6 (permalink)
boopie's Avatar
View boopie's Photo Gallery
Yeah you might wanna check the speedo cable that goes to the tranny. Just trace it and you'll find it. It might be disconnected there.
boopie is offline   Reply With Quote
Old 09-29-2009, 12:11 AM   #7 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
Didn't have to seat the speedo cable on the sr5, it sits in a spot inside the dash that holds it in place. Sedans don't have that?
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 09-29-2009, 07:29 AM   #8 (permalink)
BORICUA
jungobaez's Avatar
FB, what do you mean "it sits in a spot inside the dash that holds it in place"
Edwin "Jungo" Baez
Old 09-29-2009, 07:41 PM   #9 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
It has a bracket that holds it in place, aligned with the speedometer so it just plugs in whan you put the gauge cluster in place. I am not sure if the earlier cars have that, but my '92 did.
Speedo cables brake more often than gauges go bad. Pull the cable out of the tranny, and see if is broken.
It should be a two piece cable that disconnect just below the intake manifold.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 09-29-2009, 08:34 PM   #10 (permalink)
BORICUA
jungobaez's Avatar
Thanks, I'll check on that this weekend.
Edwin "Jungo" Baez
Old 09-30-2009, 10:02 PM   #11 (permalink)
Gameroom cash: $134355
the ae92's break the lower pieces all the time..... easy to replace....
Old 10-01-2009, 05:40 PM   #12 (permalink)
Vroom?
freakinbox's Avatar
mine is an 89 so that's almost as early as it gets, pretty sure the 88 had the same. I was half asleep when I typed that so my descriptive skills were shit. From what I remember the speedo cable doesn't really clamp to the cluster so that bracket is kind of necessary .
Old 10-01-2009, 09:20 PM   #13 (permalink)
BORICUA
jungobaez's Avatar
Thanks again guys, I'll chec it out this saturday before i head out to Indiana.
Edwin "Jungo" Baez
