Electric diagram - 4A-F engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-28-2009, 02:10 PM   #1 (permalink)
View Bolanbak's Photo Gallery
Hi all.
Please if anyone can post me electric diagram for 1.6 16V 4A-F engine. I have mounted it in Strarlet but having trouble with connecting carburator wires (electric choke), or if someone could tell me where do those wires connect to (relay, distributor or anything)....
Please help. When buying engine i forgot to take the "other" side of carburator connector.
Thx
Bolanbak is offline   Reply With Quote
Old 09-30-2009, 08:08 AM   #2 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
see your private message.. since I cannot post a file here..
I have no idea what a Starlet is,, but have Corolla diagram..
1989 Toyota Corolla SR5, Carb.
1993 Camry LE
retiredat44 is offline   Reply With Quote
Old 09-30-2009, 11:36 AM   #3 (permalink)
it is very possible that a Starlet in another country has nothing in common as far as the carb and electronics with the carb and electrical on California smog Corolla 4A-F car vs a Starlet... they are probably way different.. but, if mine helps,,, that's cool, if not, maybe someone else can help you..
1993 Camry LE
Old 09-30-2009, 11:16 PM   #4 (permalink)
View darth-grantius's Photo Gallery
Yeya starlet conversion. Over here people put rotors in them.
darth-grantius is offline   Reply With Quote
Old 10-01-2009, 08:29 AM   #5 (permalink)
View brkicv's Photo Gallery
Can you send me diagram?
brkicv is offline   Reply With Quote
Old 10-01-2009, 10:19 AM   #6 (permalink)
Starlet is for sure different of Corolla. It has a different engine and some similarity in wireing, this what I made is quite a bit of chemistry with mounting another engine inside. Re-welding engine holders and stuff like that. It would be easy when I would know how does the carb solenoids (all those wires) connect and function. It has nothing to do with original wireing. Engine is running but not the way it should cos of choke, idle control. I know now they connect to "emission control computer" which I dont have so I would like to replace it with some manual switching. If you can help please do. Thx....
Old 10-01-2009, 05:37 PM   #7 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
Don't think the weber carb uses any of that. Could always put one of them as a replacement.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 10-02-2009, 03:02 AM   #8 (permalink)
So you suggest to close all the vacuum tubes and fit in another carburator. Have some in mind to look for?
Old 10-02-2009, 05:21 PM   #9 (permalink)
Vroom?
freakinbox's Avatar
well I am not sure if it closes off all the vacuum lines. But either way would solve the issue of the electronic controlled carb and having to wire that up.
