Clutch Hose: 4AGE to 4AFE differences? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-28-2009, 03:54 PM   #1 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
Hi all, does anyone know or have both engines that you can tell me if there is a significant difference between the clutch hydraulic hose of the 4AGE vs. the 4AFE?
In all the parts listings, the GTS model is discontinued and all that is left is the "FWD exc. GTS" part. I can't imagine that it would be much different, but I don't know. If it is different, then I guess I'll have to find a comparable brake hose.
Thanks
SuperRA is offline   Reply With Quote
Old 09-28-2009, 05:39 PM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
There's no difference from what I know. I got my lines out of a SR5 when I did my trans swap.
All the trans are the same, so...
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 09-28-2009, 06:59 PM   #3 (permalink)
Thanks, I guess i figured it had something to do with the different thermostat housing on the 4AGE maybe.
Old 09-28-2009, 08:54 PM   #4 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
I bolted the slave cylinder and clutch line from my SR5 onto my 20V w/ a C56 and it fit perfect.
'81 BMW R65
Old 09-29-2009, 01:37 AM   #5 (permalink)
Ok well, I'll buy one of the "non GT-S" hoses and see. I guess it's only $8.
Old 09-29-2009, 07:44 PM   #6 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
I believe the one for the GT-S has a longer solid tube section to get around the thermostat housing, but you can make either work.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 10-06-2009, 01:52 PM   #7 (permalink)
Ok, so i ordered a "non GT-S" hose and it appears to be identical to the GT-S original hose. So less need to worry when ordering. FYI.
