blower motor problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-29-2009, 02:48 PM   #1 (permalink)
Wonderbread
4agetercel's Avatar
Gameroom cash: $160040
View 4agetercel's Photo Gallery
So im fnally getting the car all ready to be certified and i realize the damn blower motor for the heat doesnt work, and thats insta-fail because its fall and winter is almost here,
so heres the situation, when i go to turn it on, the relay clicks, but the motor doesnt turn on, i took the motor out and hooked it up straight to the battery and it works, so im not exactly sure where to go from here, i used a tester light on the plug where it plugs into the blower and nothing, so i kinda hit a dead end, because the relay is working, maybe the resister is cooked
Thoughts?
4agetercel is offline   Reply With Quote
Old 09-29-2009, 03:27 PM   #2 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
I would suspect the blower resistor and possibly the circuit breaker for the fan. It's located behind passenger kick panel in a fuse block with the relay. It has a hole in top to reset it (with a small nail) if it pops.
90 GP is offline   Reply With Quote
Old 09-29-2009, 03:45 PM   #3 (permalink)
Wonderbread
4agetercel's Avatar
well its not the circuit breaker, i just went out side and tried it, when you cycle through the speeds there should be power going to the resistor yes?
Old 09-29-2009, 05:02 PM   #4 (permalink)
I am not a wiring expert but here is a wiring diagram if you have a volt/ohm meter to do some tracing. See diagram 6 for heating/cooling.
http://opc.mr2oc.com/online_parts_ca...CorollaFWD.pdf
Old 09-29-2009, 05:36 PM   #5 (permalink)
View JasonK94Z's Photo Gallery
Same problem here and couldn't figure out what was wrong. The blower resistor was still ok (new one didn't fix the problem).
I ended up wiring up the fan to the relay box in the drivers kick panel so it's on all the time. This is a $500 car mind you. The A/C switch and the fan speed control went out at the same time last year with the previous owner. The relay in the passenger kickpanel is good, etc. I bought a new/used working climate control unit, and that didn't fix it either.
I had to rig the AC clutch to a switch also to make the AC come on as well.
Apparantely there is supposed to be a AC clutch relay somewhere? I'll be damned if I can find it.
1992 Geo Prizm Red
248k miles on it so far 9/9/09 and still in great shape!
4AFE engine, A131L 3-speed auto trans
1994 Camaro Z28 - The modified gas guzzling beast
JasonK94Z is offline   Reply With Quote
Old 09-29-2009, 07:29 PM   #6 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
I would check the resistor first.
I can't remember if the power goes from the switch to the resister, or if the switch gives it ground. You need to check the wiring diagram.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 09-29-2009, 11:14 PM   #7 (permalink)
Wonderbread
4agetercel's Avatar
just talked to my buddy, he says the switch gives a ground, so tomorrow im gunna check it out some more and update
thanks for the wiring diagram info, im sure itll help tons if i have to rip apart the wiring
Old 10-05-2009, 12:45 PM   #8 (permalink)
Wonderbread
4agetercel's Avatar
ok... so theres power and grounds going everywhere but to the circuit breaker... there isnt power or a ground,, so i think he problem is somewhere in the harness
Old 10-05-2009, 04:01 PM   #9 (permalink)
I am having an intermittent problem with my blower so will be curious on when you find the culprit. I was looking over the circuit and the 100 amp alt fuse looks like it feeds the blower circuit breaker. The fuse is located in the small enclosure off the positive terminal. Try cleaning the terminals on the fuse or replace it. To do either slide the rubber boot down and pop the plastic covers on both sides. You will need 8mm and 10mm socket to remove the bolts that hold fuse in place.
Old 10-05-2009, 04:34 PM   #10 (permalink)
Wonderbread
4agetercel's Avatar
i figured it out, i had a look at a diagram, and it showed the C/B power goes straight to the 100amp alt fuse like mentioned by 90 GP, so i started from there back-tracking to where it enters the firewall, near the firewall, around where the cruise control is there is a coupler that was unplugged, i plugged it back i and BAM had power to the blower motor again,
if you have an intermitant problem with it you should check that connection, see if its corroded 90 GP
Old 10-05-2009, 04:57 PM   #11 (permalink)
I will have to check it out. I don't have cruise so is that connector on the driver or passenger side of firewall? Is it visible in engine compartment or under the dash?
Old 10-05-2009, 06:19 PM   #12 (permalink)
Wonderbread
4agetercel's Avatar
its in the engine compartment, right by the strut tower, you cant miss it
Old 10-05-2009, 07:36 PM   #13 (permalink)
Gameroom cash: $134355
have you tried at multiple settings? Not 100% sure about which models have which, but typically there is a separate relay for the high setting. I have seen it before where it fails at all low settings but worked on the high setting. This was in an aw11 and all I replaced was the switch itself.
Old 10-05-2009, 09:32 PM   #14 (permalink)
Wonderbread
4agetercel's Avatar
lol nah i figured out the problem, read a couple posts up
Old 10-06-2009, 03:04 AM   #15 (permalink)
Thanks I found the wire. Unfortunately no corrosion so I need to dig further.
