Originally Posted by Drainx
I think 'bearings at the end of the gearbox' are the ones connecting the transmission to the rear driveshaft and/or the center driveshaft. A friend of mine had the same problem a few weeks ago with his bmw on the center bearing where its held to the underside of the chassis.
Sounds logical. And I think that the intermediate shaft that goes to the rear axle (or what it's called, excuse my english) has bearings as well. Main question is: do I have to worry about this noice?
Originally Posted by stancati
The wheel bearing will make different noises when turning left or right depending which bearing is bad. If the wheels feel solid (assuming u felt for play in the wheels and driveshafts and not just the driveshafts) when the car is jacked up, then it may still be the wheel bearing, spin the wheel with your hands as fast as you can, and listen real good for any grind or roughness, usually a good indicator is the faster the wheel spins (ie. the highway) the louder the noise will get.
I doubt its the actual transmission, as then u would only have issues in that gear or all the time regardless of turning depending the issue that is.
Yeah, I know that bearings in general can be tricky to sort out whether they are good or not. Spinning the wheels by hand don't get anything and it's (more) komplicated to test a 4WD in a garage by simulating driving since all 4 wheels have to be jacked up.
This IS a typical noice from a bad bearing. It has low frequency - so low that it can hardly be heard in low speed - and when speed exceeds 70-80 km/h there are other sounds from tires, engine etc that will drown that sound.
