Wheel and tire question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2009, 12:43 PM   #1 (permalink)
View Nickernator's Photo Gallery
AE92 Wheel and tire question
I own a 1988 corolla gts. I just picked up a set of 16x7 wheels with 45mm offset. I had 15x6.5 with 40mm offset on it with no problems. Does anyone know if I will have clearance issues? should I run a 5 mm spacer?
Also I have been unable to locate the oem offset for this car. anyone know this?
Thanks in advance
Nickernator is offline   Reply With Quote
Old 10-01-2009, 01:26 PM   #2 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
you're going to need a spacer. at least a 5mm spacer, maybe a 10mm for the rears.
I would just throw them on and see.
'81 BMW R65
Old 10-01-2009, 03:00 PM   #3 (permalink)
Gameroom cash: $100900
View 4doorGTS's Photo Gallery
Yeah your def. going to have to run a spacer in the rear with a 7" width and et45.
Stock gts rims are 14x5.5 et39. I have 16x7.5 et35 and I couldn't fit a hair in between the strut and rim without a spacer.
4doorGTS is offline   Reply With Quote
Old 10-01-2009, 04:45 PM   #4 (permalink)
Rotary guy...
eage8's Avatar
I have 15x7s +35s with 205s and the rear sidewalls rubbed against the struts.
'81 BMW R65
Old 10-02-2009, 01:40 AM   #5 (permalink)
1990 Corolla GTS 4A-GE
Createdtoburn's Avatar
View Createdtoburn's Photo Gallery
I have 15x7 with +36mm offset with 205/50/15's and the front clears no problem but my rears probably have 1mm or under of space between strut and tire. I have a 89 GTS. I might just get some 195/50/15s for the back so I deff have no problems.
Createdtoburn is offline   Reply With Quote
Old 10-02-2009, 09:30 AM   #6 (permalink)
Rotary guy...
eage8's Avatar
I got some H&R 10mm spacers for the back of mine, I think it looks really good. It lines that back tires up with the front tires more and makes them flush with the fenders.
'81 BMW R65
Old 10-02-2009, 10:57 AM   #7 (permalink)
I dont really like the idea of wheel spacers. I think they should be avoided whenever possible. It's just one extra thing between the wheel and hub that could cause vibration and over a period of time cause loosening of your lug nuts and I'm sure not a lot of people check their lug nuts tork on a regular basis.
Old 10-02-2009, 11:26 AM   #8 (permalink)
35 mm offset and you still have clearance issues? I would need a +10mm spacer to clear, right?
with a 10 mm spacer did you lengthen you studs?
Old 10-02-2009, 01:01 PM   #9 (permalink)
Rotary guy...
eage8's Avatar
mine are hub centric, so they don't really go anywhere.. I can take my wheel off and they stay on the hub right where they're supposed to be.
10mm spacers will put you at the same offset I had on my 15s and the rear tires rubbed.
I would get 15mm spacers ( at least, maybe 20mm) in the back, and 10mm or 15mm in the front.
but I've never had 16s on my car so I don't know. you might want to get 195 tires too so you'll have less issues.
My H&R spacers came with lengthened wheel studs. I test fit the 10mm spacers without them and they wouldn't have worked.
'81 BMW R65
Old 10-04-2009, 11:54 PM   #10 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
This is good, I'm planning on getting 15"x6.5" 40mm.
I tried 17" that came off a older model VW Golf. I'm not sure of the offset, but it fit CLOSE. The right rear rubbed because it had a newer tire. Also, full turns had fender intereference. Above all, those wheels soaked up power. Engine rev to go nowhere...
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 10-05-2009, 05:05 AM   #11 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
yeah spacer for sure. I have 16 x 7 with a 42mm offset I think. And the rears rub off the rim protector on the tire.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 10-05-2009, 07:20 PM   #12 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
16x7 with 45mm offset... for sure will rub, sell them as they're no use to you, or yeah get spacers and hope that the wheel doesn't rub AND there's enough stud left for the bolts to grab on to.
OEM GTS wheel offset is 39mm, is stamped right on the wheel itself. (14x6 I believe is the wheel size)
RULE OF THUMB: wheel size, width and offset is usually A. on a sticker on the wheel itself, or B. stamped on the wheel itself. I post this because I know people are going to search this next time.
