no power after new head gasket
1990 corolla 1300, ran real well untill head gasket blew, replaced head gasket & planed head, assembled fine but engine has no drive at over half throttle, stripped carb & cleaned=same result.
Checked to date: swapped carb with unit from “good” car= same result, swapped fuel pump= same result, checked cam timing, ign timing, compression, all vac lines & non-return valves in correct position.
Installed video camera in engine bay to check secondary butterfly is opening at full throttle under load, result= it is.
Swapped inlet manifold in case one of the vacuum valves on the back was shot=same result.
it never misfires just doesn’t pull, top speed is 110 kph !
Kinda run out of ideas now !
If anyone has any suggestions, that would be very welcome.
